911 turbo down on boost?
Old Mar 28, 2008 | 09:27 PM
horsepower1's Avatar
horsepower1 is infamous around these parts
I just bought a 2002 911 turbo, tiptronic.
it is only making .4 to .5 BAR boost, and feels slow? I'm counting like 6+ seconds to 60mph. what could be wrong? is there a valet mode or something I'm missing? Just filled up with 93 octane shell. car is mint, low miles, so must be something stupid.
please help!
Old Mar 28, 2008 | 10:28 PM
is .4 or .5 BAR normal?
Old Mar 28, 2008 | 10:58 PM
ezmoney888's Avatar
ezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond repute
I think most see .6 to .7 unless it was flashed.
Old Mar 29, 2008 | 07:36 AM
996Choy's Avatar
996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of
.5 is low .. boost leak?
Old Mar 29, 2008 | 07:51 AM
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
Leak
Old Mar 29, 2008 | 08:21 AM
powerstar's Avatar
powerstar is infamous around these parts
broken blow off valves
Old Mar 29, 2008 | 10:21 AM
mikerosi's Avatar
mikerosi is a jewel in the roughmikerosi is a jewel in the roughmikerosi is a jewel in the rough
I think everyone who owns a turbo car should LEARN to test the turbo pressure lines. It is simple. I searched this forum and I think "zippy" posted a DYI for this.
You just plug one end of the turbo before it goes into the IC on one side and then make a TEE with an air hose fitting along with a pressure gauge fitting on the other side. This is all PVC stuff---real simple. Get your compressor to make 12 or so psi, verify it on the pressure gauge of the Tee and start listening. I used a spray bottle with soapy water and YOU DON~T want to know what I found!!! well maybe you do----my DV`s were leaking like an Irishman after ST PattY`s day.........EVERYONE should be doing this esp on higher boost cars OR you can pay the dealer to do a "smoke test" for 150 per hour
Old Mar 29, 2008 | 10:25 AM
please help!
Please disconnect the battery for 5 minutes to reset the ecu... then go get on it and test...
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 29, 2008 | 11:33 AM
996TTs's Avatar
996TTs is a jewel in the rough996TTs is a jewel in the rough996TTs is a jewel in the rough996TTs is a jewel in the rough
I have a 2003 TT (non-X50) with the only modifications being a K & N Filter and a Techart racing exhaust.
I am consistently getting .9 BAR boost. Is this normal? I feel like it's pretty good considering X-50s are getting .8 and .9 BAR. Am I wrong?
Old Mar 29, 2008 | 07:09 PM
arr0gant's Avatar
arr0gant is infamous around these parts
I have a 2001. I get between .6 and .9 Hardly EVER .8 or .9 I have to push hard and usually get .7 and easily get .6
Old Mar 29, 2008 | 07:30 PM
contigo's Avatar
Thumbs up
GOOD POST THANKS!!!!
Old Mar 29, 2008 | 07:45 PM
oak's Avatar
oak
crappy gas. quick pull my finger...
Old Mar 29, 2008 | 09:52 PM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
I'm curious ... does it reset the ECU if I just "reload" the program instead of disconnecting the battery?? I'm using the UMW programmer ...
Old Mar 30, 2008 | 06:54 PM
r34dy2walk's Avatar
r34dy2walk is infamous around these parts
if your running a non-x50 setup, you should be getting around .7 bars. your car was flashed.
Old Mar 30, 2008 | 09:21 PM
996TTs's Avatar
Thanks for the input!
Even with the K & N Filter and the Techart Racing Exhaust?
I would have thought that these two would have added boost from the typical .6 or .7 that a stock TT would get.
