Help with stripped screw on MAF
Hey guys,
I'm trying to replace my MAF sensor and one of the screws/bolts is stripped. Its not the standard Star/Security Torque screw. Mine were replaced when a V-flow was added and the current are standard Hex pattern. My problem is that the inside of the pattern has degraded and I can't get it to loosen?
Any ideas? As a last resort I could crazy glue a hex bit to the screw and then just replace (Screw and bit)? There is no edge to the screw so I can't use pliers etc. (no lip to grab a hold off)
Is that a stupid idea? Bit replacement for an entire set is 10 bucks at home depot so its not that big a deal.
Also anyone know what the standard size length of that screw is and where to buy a replacement?
Is that a stupid idea? Bit replacement for an entire set is 10 bucks at home depot so its not that big a deal. Also anyone know what the standard size length of that screw is and where to buy a replacement?
Take a Dremel tool with a cutting wheel and cut a slit in the head of the stripped screw. Cut it deep enough to get a flat-head screwdriver in it, and then just unscrew it with the flat-head.
When you cut with the Dremel, be sure to cover up any important stuff, because there will be metal shavings all over.
