More bars in a 996 tt ?
SubscribeI have a 996 tt with 600 hp evoms and water methanol inyection and my bars wont go higher than 1.3.
I tried moving the waste gate nuts and does not make a difference.
Any suggestions on how to achieve 1.5 bars?
Will a turbo XS boost controller help me achieve this?
Regards
Regards
What turbos are you running? If you are running a K16/24 or K24, you don't want to run that much boost...it will be out of the turbos efficiency range and create a lot of heat. Now if you have Garrett hybrids or something similar, you probably could, but it might be detrimental to your motor.
Your done at 1.3, you need bigger turbo's and different programming. The ecm will shut down and go into limp mode if you exceed 1.3 bar, and you will just start making to much heat, not good for the motor.
yep, your throttle plate will close, you need new programming then run an external boost controller like the Greddy Profec B. PM me.
thank you sir
We have a big dealer in Mexico, I can have him do any work you need. Let me know.
yes VIVID RACING ,i am very interested.thank you.
Shoot me a PM with your location.
Mexico City
I Did It My Self Sir,i Got It In E Bay ,i Put A 2 1/2 G.tank Use 50%water- 50%methanol. I Beat Cars With 700 +hp , 911 Tt 997 I Used A 6 Gph Nozle Very Close To The Throtle Body After The Sensor And I Start It A .6bars They Envy Me
Hey "vivid Racing" I Have Not Heard From You... I Think You Just Talk Because Of The Weight Of Your Jaw Or Is It Not?
LOL. Hector, I am getting the contact info for you. Please be patient, it has been less then 1 day. I will make sure you are taken care of.
Vivid Racing Thank You. And I Am Sorry
