K24s for 600hp ???
Old May 11, 2008 | 01:33 PM
dreamtripper's Avatar
dreamtripper is infamous around these parts
K24s for 600hp ???
Is it possible to get a solid 600-620 crank hp on K24s? I currently have the stock K16s and don't see myself needing more than 600-620hp so future upgradability of the K24s is not a big deal.
Is upgrading to K24s as simple as swapping out the turbos and using an appropriate K24 flash? Incidently, most of the K24s flashed I've seen dyno under 600 hp. What are the "must dos" and the "nice to dos" with a K16 to K24 upgrade.
Lastly, if K24s are not capable of producing this kind of power, what's a good alternative?
Thanks!
Old May 11, 2008 | 01:35 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
24/18's
Old May 11, 2008 | 01:40 PM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
Like Paulie said, Protomotive 650 setup. 24/18's, 5bar, dv's, exhaust and Todd Knighton's magic.
Done.
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Should be able to no prob
Old May 11, 2008 | 01:45 PM
Any idea of what this costs ballpark? Seems like a fairly simple set-up.
Done.
Old May 11, 2008 | 01:55 PM
$manager's Avatar
I bought a set of used 24/18's from a board member for $2800 w/ the wastegates done.
Next is a $3407 deposit into Protomotive's account for:
ECU: $2975
Greddy $432
I already had the 5bar, dv's and exhaust.
So...$6,200 total for the package [but again I already have exhaust, 5bar and dv's]. I think you would be hard pressed to find any package out there that is less expensive in a $/hp ratio. What's that....$10 per hp?....and for a proven and reliable package...hard to beat!
Old May 11, 2008 | 02:17 PM
Seal Grey Matte's Avatar
Seal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to behold
My K16/16G package from EPL makes approximately 600 crank.
It consists of a 16g compressor and wastegate actuator upgrade to a set of stock K16 turbos, a 5bar FPR and a custom tune from Tony at EPL. All told, you'll spend less than $3500. I consider that a pretty good bang for the buck
Old May 11, 2008 | 05:07 PM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Thanks!
If 600 is your goal, you can get there with k24's. If you have no plans to go beyond the 600...I would keep the k24's as is and not have 18g wheels installed. You will have slightly better response and it will save you money.
Old May 11, 2008 | 05:18 PM
I have better spool w/24/18's than I did w/ 24's.
Old May 11, 2008 | 05:48 PM
Tony@epl's Avatar
We've tested many cars and usually see a 100-200 rpm difference.
Did you change anything else at the same time? Most likely your programming?
Old May 11, 2008 | 05:56 PM
unvmy996's Avatar
ditto same here .... i have ported and polished and swain coated manis also.
Old May 11, 2008 | 06:08 PM
Tony@epl's Avatar
Here is a quick compare, and I can post more tomorrow when Im in the shop...
So 2000-3200 ish you guys are correct, the k24/18g's in this case have the advantage, but 3300 to 4600 or so the k24's really wake up faster.
Perrew
993 Turbo
Dec 9, 2016 08:35 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
BlackMarketRacing
Dec 3, 2015 10:46 AM
Glasig
Aug 23, 2015 03:35 PM
