Oil Change?
Old May 13, 2008 | 08:59 PM
wross996TT's Avatar
Originally Posted by schred
Maybe I had better read my manual again, as I thought 0w 40 was the reccomended viscosity from Porsche ? And yes, change the filter, it is cheap and why leave a dirty filter in. Dont forget to drain the oil from the turbos as well .
It's not the manual....it is the latest TSB....0W40, 5W40, 5W50 all approved.
Old May 13, 2008 | 09:53 PM
spoonito's Avatar
spoonito is infamous around these parts
Never changed oil in a turbo car (will be picking up the 996TT on Saturday!!!) How do you drain the oil from the turbos?
Old May 13, 2008 | 10:22 PM
schred's Avatar
schred is infamous around these parts
Easy,, there is a small drain plug that is clearly visible. It is at the bottom of a small oil resevour just behind the turbos. You will see it. Make sure and get a total of 4 crush washers and 1 filter for the job. 8.5 quarts of oil as well. To drain the oil tank it takes 2 big wrenches, you need to back up the lug on th botom of the tank and the tank drains fast. Really fast!!!
Old May 14, 2008 | 03:57 AM
Mikelly's Avatar
I never drain the turbos...
Did it once, and saw the tea spoon of oil it produced and decided that as often as I change mine, it'll keep.
Always change the oil filter when you swap the oil.
Mike
Old May 14, 2008 | 03:58 AM
Mikelly's Avatar
Originally Posted by smokinxtreme
Hey Guys Can You Use Mobil1 0w40........
Mobil1 0W40 is the type that has had changes to the base stock, and is what I've switched from, due to that change...
Mike
Old May 14, 2008 | 06:00 AM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
Conclusion of post first: If you look in the manual, the interval is well over 3,000 miles per change. So, each of us has to do what we feel is prudent.
Body of post (skipping ok as it just concludes with the above): I for one feel the cool down is the critical step...1 minute if I have not be on boost, 2 minutes if I have been on boost within 10 minutes. My rule. No data ok...just reading lots of posts here and asking around. Also, not abusing it (full boost cold, etc.).
I plan to change my fluids q 7500 miles. Perhaps once extra for DE days.
My diff fluids after 1 DE that was over 3 days (green) and 30k miles, per a master Porsche mechanic, were pristine. Tranny/front/rear. I suspect the prior owner cleaned then up at the sale mileage at 15,000 and I am pretty nice to my car(s) always (OK, I baby her). May be just my luck. I don't know. I'll do them at 60k or 45k...I plan to check them every 7,500 with oil changes. Shifting is superbly smooth. It is deliberate to avoid a money shift too..... I mentally take a split second to pause in shifting, even on track...my way of being smooth. If I ever need to race...I won't bother doing so without a sequential box paid for by a sponsor. Probably on a cup car or some such beast.
If I could get 5w-50 Mobil 1 in the US I would use that. Until then, I am going to either use 5w-40 turbo diesel/Delvac as per Mikelly or 0w-40. I don't think I as an end user push the car beyond this plan..... 550hp or so.
Anyone know a place to get 5w-50 mail order M1?
JB
Old May 14, 2008 | 07:19 AM
996Choy's Avatar
996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of
mobil1 5w50 is available in japan but it's expensive beyond belief - us200 for 4L
Old May 14, 2008 | 09:42 AM
unvmy996's Avatar
why are you guys using turbo deisel oil as oppose to regular ? what is the benefit?
i use valvoline non synthetic as recomended by my tuner TK.and freind Mark.
Old May 14, 2008 | 09:45 AM
joyride's Avatar
joyride has a spectacular aura aboutjoyride has a spectacular aura aboutjoyride has a spectacular aura about
wow.. that is like $400+ US per oil change!
How is the Eneos 5w40 in japan? more expensive than M1 5w40 ?
Old May 14, 2008 | 09:50 AM
joyride's Avatar
It's all about the ZDDP additive... (anti-wear additive)
the new SM cert gasoline engine oils have very low ZDDP levels.. i think the max allowed is 800 PPM. (low zddp increases catalytic converter life)
Also, the new SM oils have less detergents and less acid neutralization.
M1 0W40 is a SM Cert oil now.
That's why I use M1 Delvac Truck and Diesel 5W40.
Old May 14, 2008 | 09:51 AM
+1.
JB
Old May 14, 2008 | 10:29 AM
unvmy996's Avatar
ah , i didnt know that , that is the reason why i was told to use valvlonie racing non synthetic. cuase it has all of that in there..
so joy ride, the mobil one devlac, is it synthetic ?
Old May 14, 2008 | 10:36 AM
It is. Also called Turbo Diesel Mobil 1 synthetic (at least at the Pep Boys around here in Pennsylvania).
JB
Old May 14, 2008 | 10:47 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
JB
So, that's why some people said they can get oil from Walmart; I do know that they sell Turbo Diesel M1 and not the one for European cars.
Old May 14, 2008 | 10:55 AM
5w-40...
jb
