Want to replace OEM Battery. Which one do you guys like?
I have a 2004 996 TT X50 and would like to replace my OEM battery with a lighter and smaller setup. What batteries are you guys using? How many days will a smaller battery keep charged up? Could you post some pictures of your setup.
Thanks, G
Thanks, G
Jimmer, did you fabricate that battery mounting bracket, or did you just buy it? I want to put an optima in, but I don't want to buy a special bracket.
If you did fab it up, do you have any directions??
Thanks!!
Thanks!!
i have the same battery as jimmer as well.
battery holds great with maybe 15lbs of weight savings.
i fabricated my bracket with a long piece of aluminum from home depot. i bent it appropriately and put the screws as well. just make sure you align everything well. i found a diy somewhere im sure you can search it.
Been running an Odyssey 928 for 2 yrs....works.
My car never sits for more than a week to 10......no problem.....winter use trickle.
OE batt is 51 lbs
Optima red.....38 lbs
Odyssey 1200..38 lbs
Odyssey 928.....26
OE batt is 51 lbs
Odyssey 928.....26
