Sputtering at 4K RPM?
Old May 18, 2008 | 07:20 AM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
you can clean your maf with elec cleaner a 5 min job try it .. i did after spend a couple of grand on plugs and misc other stuff.. the cleaner cost two bucks at ace hardwear...
Old May 18, 2008 | 11:50 AM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
steve harris which wing is that on the car in your avatar?
Old May 18, 2008 | 12:16 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Again, hope it is the MAF. yes it is expensive but less than putting Plugs.
Old May 19, 2008 | 05:51 PM
turboporsche's Avatar
turboporsche is infamous around these parts
I had a similar problem from 2500-4000 RPMs. It turn out to be a boost leak.
Old May 19, 2008 | 06:00 PM
r34dy2walk's Avatar
r34dy2walk is infamous around these parts
Sputtering?? Really?
Mine went away after replacing plugs. I've had nightmares with this issue between the MAF and plugs.
Old May 19, 2008 | 06:28 PM
boca996tt's Avatar
how much is it to change out all the plugs... labor & parts?
Old May 19, 2008 | 07:03 PM
r34dy2walk's Avatar
around $800 at the dealer.
$500 at a local shop.
$80 if you do it yourself. lol.
mikerosi's Avatar
mikerosi is a jewel in the roughmikerosi is a jewel in the roughmikerosi is a jewel in the rough
Hey Ari, what was the fix for your problem???
Old May 19, 2008 | 07:22 PM
Turbo Fanatic's Avatar
Haven't looked into it yet. But I can't repeat the sputtering issue now.
I put in 5 gallons of 100 octane last week just for kicks and the issue started when I filled up with 91 Octane the next time. I'm wondering if the computer just needed to back off timing?
Old May 19, 2008 | 09:32 PM
ezmoney888's Avatar
ezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond repute
Ari, mine did that sputtering for a split second thing off and on. Then after a while the CEL would come on...but never stayed on. Then it was time to change the plugs anyway but when I did, it needed 2 coil packs. So don't drive it too long in that condition. My aftermarket warranty covered it so I don't know exactly how much it was for just the plugs.
Old May 19, 2008 | 11:41 PM
art4iza's Avatar
Sounds like Plugs now. Did you try to disconnect the MAF?
Old May 20, 2008 | 12:59 AM
Zippy's Avatar
I was going to suggest gas. Went on a road trip Sunday and the car would lightly sputter @ >4000 RPM in 5th and 6th. Car dropped flat on its face. Had 91 in the car. Added a can of Torco and topped up with 94 and pulled hard to redline. Must have been pulling timing.
Oct 2, 2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
shifter_
Sep 30, 2015 04:00 PM
