Sputtering at 4K RPM?
Old May 17, 2008 | 11:33 AM
Turbo Fanatic's Avatar
I noticed yesterday that the car seemed to be sputtering at about 4-4.5 K RPM at full throttle and under full boost. Especially in the higher gears (4th gear plus)
Does this sound like bad gas or do I need new plugs? It's been about 10K miles since I last did plugs.
Old May 17, 2008 | 11:51 AM
unvmy996's Avatar
deff plugs .
Old May 17, 2008 | 12:19 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
That's a classic plug scenario, but 10K seems very short for plug life.
Old May 17, 2008 | 01:10 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
How about MAF. Do you have OEM air box? Disconnect MAF and try it again. IF the car opens up good then it is the MAF, if still having problems then Plugs. I recommend GT2 plugs, ask Dan at SG.
Old May 17, 2008 | 01:13 PM
art4iza's Avatar
Just bought a GT750 RUf.
Sold the Gemballa GT700 for a good price. Got a RUf with X50 package and upgraded to GT750. I will post pics soon.
Art
Old May 17, 2008 | 01:37 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
One of 3 things
Plugs...Most likely
Maf
Boost leak..possibly bad DV's
Are you getting a CEL? If so pull the codes.
Old May 17, 2008 | 02:08 PM
art4iza's Avatar
Sounds like MAF to me, let's bet on this.
Old May 17, 2008 | 02:16 PM
ezmoney888's Avatar
ezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond repute
I just had the same thing and replaced plugs. But I found I had 2 bad coils as well. Replaced them all and now runs perfect.
Old May 17, 2008 | 02:36 PM
996twin_sc's Avatar
996twin_sc is infamous around these parts
Plugs....I was hitting stuttering at the same rpms as you. New plugs = no problem anymore.
Old May 17, 2008 | 02:39 PM
Running the EVO intake with the "fix" have had no MAF issues since.
My gut says plugs.
No CEL BTW.
Old May 17, 2008 | 09:56 PM
art4iza's Avatar
Did you get a check engine light? If yes, what does it say?
BLKM3's Avatar
BLKM3 is infamous around these parts
I will bet its plugs. Good luck, I was only able to get 10k from my plugs.. I went with Bosch FR6 plugs.
Old May 17, 2008 | 09:58 PM
art4iza's Avatar
FR6 LDC or LDU?
Old May 18, 2008 | 02:19 AM
Zippy's Avatar
Most likely plugs. Could also be coil pack. Could also be injectors. I had a couple of bad injectors that created bad sputters @ 4500 RPM at WOT.
Old May 18, 2008 | 07:17 AM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
mine did the same thing a few years ago . tried plugs , and lots of other stuff (costly) turned out to be my MAF .. caused by a oil air filter goat apaper one all has been well ever since
