Draining Gas Tank?
Old May 19, 2008 | 09:25 AM
slant911's Avatar
slant911 is infamous around these parts
Draining Gas Tank?
Sounds crazy but what is the best way to drain the gas tank? I don't believe I can shove a siphon hose down in there because of the electronic flap in there would stop it.
I need to do the recalibration procedure for the fuel guage which involves draining the tank then putting in a predetermined amount of fuel before the calibration procedure.
TIA
Old May 19, 2008 | 09:47 AM
WOODTSTER's Avatar
You can drain it from under the front bonnet.
There are (4) nuts on top of the gas tank that removes the "inspection lid",
be careful with the stuff attached and it can be set aside for easy siphoning.
MK
Old May 19, 2008 | 10:23 AM
slant911's Avatar
Woodster,
Is the fuel sender attached to that "inspection lid". And is it the giant square thing right in front of your face when you open the trunk?
Thanks.
Old May 19, 2008 | 04:07 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
I thought there had to be a drain plug, but Marty is right - here's what the shop manual says:
1. Disconnect the battery and cover terminal or battery.
2. Remove cap over the fuel level sensor system.
3. Remove fuel level sensor. ’ Rep. Gr. 20 66 19; Removing and installing fuel pump.
4. Using a fuel extractor, completely drain the fuel tank through the fuel level sensor opening. Fuel extractor:
Refer to the Workshop Equipment Manual, Chapter 3 "Workshop Equipment".
5. −Make sure that the two recesses on the left and right−hand sides of the tank are emptied
completely.−
6. Reinstall the fuel level sensor and, with "ignition off", fill the tank with
−28 litres− of fuel.
7. Perform tank calibration with the Porsche System Tester 2:
Select vehicle type (911 Carrera)
Select control modules
Select instrument cluster
Select menu item "Tank calibration"
Confirm calibration
8. The fuel level sensor system has now been calibrated
sdg1871
Nov 22, 2015 07:27 PM
alpha motoring
Oct 2, 2015 12:04 PM
km90265
Sep 27, 2015 10:57 PM
Bobbyfali
Sep 27, 2015 01:55 PM
