SIZE OF SPACERS TO HOLLOW TWIST's TO GET "GT2" STYLE
Old May 21, 2008 | 06:23 PM
996TT MAVERICK's Avatar
996TT MAVERICK is infamous around these parts
What size of spacers do you guys use to space out so it look like the GT2???
Old May 21, 2008 | 06:28 PM
detailersdomain's Avatar
detailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond repute
I did the 6mm spacers from Boothe Designs...
http://boothedesign.com/spacers.html
I also picked up the lug bolts and they look great..
http://boothedesign.com/boltsstudslugs.html
Old May 21, 2008 | 07:27 PM
rafiki's Avatar
rafiki is infamous around these parts
I've used 6mm front and 17 rears..both supplied by dealer.
Old May 22, 2008 | 08:48 AM
SlimJim's Avatar
SlimJim is infamous around these parts
You used these on the Turbo Twist Wheels? Did you rubb at all?
Old May 22, 2008 | 10:46 AM
sandvik996tt's Avatar
sandvik996tt is infamous around these parts
I have 18mm spacer at rear, no rubb ! Orginal wheels !
Old May 22, 2008 | 10:53 AM
I just got a answer form a dealer.. And they says 15mm in front and 18 mm rear.. And i need to roll .. to avoid rubbing.. As mine is also going to be lowerd as a GT2...
Old May 22, 2008 | 11:49 AM
SlimJim's Avatar
just curious...do you guys feel anything different when you add the spacers (e.g. shaking...) also with 18mm spacers what size bolt do you need to get for the wheels?
Old May 22, 2008 | 11:54 AM
18mm longer bolts ! ( was included with the spacers ) Nothing different (e.g. shaking...) accept better looking car !
Old May 22, 2008 | 12:16 PM
SlimJim's Avatar
I know 18mm longer bolts I guess I should have added, I have no clue how long the stock bolts are
I need to get me some spacers!
Old May 23, 2008 | 04:54 AM
deandob's Avatar
deandob is infamous around these parts
Apparently adding spacers improves handling as the car track is wider??
Old May 23, 2008 | 01:21 PM
smokinxtreme's Avatar
smokinxtreme has a spectacular aura aboutsmokinxtreme has a spectacular aura about
so you guys are using spacers on your factory set-up..........
Old May 23, 2008 | 04:00 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Lots of variables here.
If you go real low, & have not stiffened your suspension, & are running any respectable neg. camber.....18" spacer in the rear added to reg 45mm offset hollows will cause you more trouble than fender prep can solve.
GT2 height is 113F (+-5mm) and 138R (+-5mm)......if you stay up a bit, stiffen, not so much neg cam....any one or como of the 3 & you may be OK.
Suggestion.....a future plan to order wheels with your desired offset....put the 18" spacers on the shelf.
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
ModBargains
Aug 20, 2015 12:28 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
