Misfirering when WOT
About 8 month ago, I got 1-2 misfires sometimes at WOT, about 5 month ago, I got 4-5 misfires at wot (3000-6500rpm), now I got about 10 misfires...
Old sparks? (I have changed them about 14000miles ago - Denso iridiums)
Ignition coils?
Wideband shows 10.2-10.3 and misfires don't change that.
Sometimes I don't have any misfires, sometimes I got them plenty, usually it happen, when cruising some time and then I hit pedal hard.
Misfiring stays when using NOS.
When I use acceleration pad gently, then everything is fine, when I floor it, then I got misfires(it happens every gear)
About month ago I replace MAF, but this doesn't change anything.
Where can problem be?
Ignition coils?
I would guess plugs. Mine only last 12-16K miles. I have not used the Densos though. I understand coil is frequently a problem also. I would check coil before changing plugs. Iam also assuming no fault codes present...??
vogz
Sep 19, 2015 01:02 PM
