New mods... help!!!
Old Jun 1, 2008 | 12:48 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
After closer inspection I discovered one of the hoses slipped out from underneath and I was able to fix it up this morning, not visible from the top and i didnt throw any lights either
Old Jun 1, 2008 | 08:00 PM
wross996TT's Avatar
Make sure this is the only issue as it does not explain the on and off and then on again condition. If you blew the hose, you should have been in limp from then on. .6 is limp mode. Sometimes the car can clear this condition by simply restarting the car. By disconnecting the battery, you are clearing active codes (some codes can not be cleared with this approach)...I think this is what you mean by resetting the battery? If you are exceeding 1.3, you could be shutting the TB...and going limp (sounds bad huh?) In any case as Mike says codes will be stored and you should get them read (you do not necessarily get lights when you throw codes!). Good luck.
Old Jun 1, 2008 | 08:10 PM
vividracing's Avatar
Joel did you get the new map?
sinister05CTT
Cayenne 955/957
17
Oct 7, 2014 09:11 AM
Bleen
Mar 31, 2014 12:56 PM
SANDOVAL
Nov 19, 2003 01:37 AM
