Help OEM GT2 Bumper
Help OEM GT2 Bumper
I wanted to do the gt2 front bumper on my 996tt. I was wondering if anybody has the part numbers to all the parts i would need to order to do this conversion the correct way. Ive been browsing the forums and supposidly i need some different brackets to move the radiators. I was hoping if someone on this forum did the conversion and has knowledge of exactly what i need to order from the Porsche dealer. I do not have any of the parts yet, so if you can supply me with the part numbers that would be awesome. Thanks in advance.
I have the oem gt2 front conversion on my car and had it done at my buddys shop that uses oem porsche paint and I also have the part numbers at home. I'll post it up for you when I get home from work. Or you can try do a search on the forum. I don't know if you are aware of price for all the parts they are pretty expensive rite now cause of the u.s currency
Melsta - I've got some paintwork that needs to be done on my car. I'm always looking for a good shop - can you tell me where it's located?
I'm in the south bay.
Cheers,
Rich
p.s. N1 kT - Sorry for the hi-jack. I meant to PM Melsta not add to your thread...
Cheers,
Rich
its located on 7th between harrison and folsom st. its called chows automotive. pm me if you want the number to the shop
you need # 1, 25 speed nut 99950725802, 6 screw,m5X16 90062301207, 6 hexagon nut 99908412002, 4, 5, 7, 8, 9, 10, 13, 16, and 17 from link below
http://www.pelicanparts.com/PartsLoo...-02-Frame3.htm
you need # 2, 2 spacer sleeve 99650467931, 3, and 9 from link below
http://www.pelicanparts.com/PartsLoo...-17-Frame3.htm
you need # 10, and 16 from this one
http://www.pelicanparts.com/PartsLoo...-15-Frame3.htm
i listed all the parts i could remember there might be a couple parts that i left out.
you will also need to extend the center radiator hose by cutting 2 piece of pipe one for each side of the center radiator or you can get aluminum joiners from here http://boostcontroller.com/index.php?category=201 if you know the size of the hose i had the shop do that part so i cant help you there.
hope this helps
hope this helps
Jul 29, 2019 11:13 AM
ECS Tuning - VW
Aug 26, 2015 12:13 PM
