Those with JIC Suspension A Few Questions
Originally posted by Rodis
I have PSS9's now but when I had the JIC medium stiff was too stiff for me. JMO
Ron
Ron
I am getting my suspension installed this weekend, and don't want to be in for suprise at the full stiff setting
have driven a turbo cab with the competition setup and drove rather smooth but skipps when your on the throttle, might have had the dampening too slow and the suspension was stacking. haven't tried on the track or canyons, but heard they are pretty damn good. the problems i have seen is the mounting AREA WOULD START TO BEND, i hope they solved that problem. other problem i have seen is the coils maybe too short considering the tops of the coil would bounce in and out of the end cap area, which causes a loud clanking noise when it pops back into place. i would think the street springs which i would assume to be slightly longer and softer would eliminate this problem or the newer models. anyhow i would assume with the multiple compression and rebound adjustments you can trick out your suspension, it's just setting it up the way you like it that matters. so if, which i doubt, the suspension has too many functions and ones knowledge on suspension setup is limited i would just go for the pss9 so you only have rebound to screw with or even more simple the H&R which has no adjustments except height. Vince your knowledge on cars is very extensive, i think you will be happy with the JIC.
Originally posted by Ruiner
Can you explain this a bit more in detail?
the "L" on the bottom of the strut starts to bend about .25" where you bolt it on.
Originally posted by 996turbo
I had it on Medium.....it made all kinds of sounds and nearly broke my back.
Originally posted by johnnie
I have the new set-up and the spring rates are fine for the street.
You can run 3-4 clicks out both front and rear on the street without probelms.
that noise is the spring moving around. they need to make a longer spring. on the new version, did they just change the viscosity of the oil?
You can adjust the height to your liking, Usually not much more than 35mm drop front and rear..You can drop it even more but makes it more difficult to do the alignment and get it right..Great track set-up even with stock sway bars car is very neutral with a little more stiffness in the rear than the front to dial out some of the understeer..
Jul 29, 2019 11:13 AM
Studio RSR
BMW //M
Aug 25, 2015 06:20 PM
