Boost?
Old Jun 29, 2008 | 04:13 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Boost?
Hello...While I was cruising in 6th gear 3-4krpm I thought i lost power...the car stop boosting over 0.5 bar...the idle is fine,the engine at low rpm with no boost is fine,no CEL,no limp mode,not even a single code just no boost over 0.5-0.6.also the engine sound from 2k and above is different(maybe because there is no turbo sound to hear)
...Any ideas?
Old Jun 29, 2008 | 04:29 PM
BoxsterGirlie01's Avatar
BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !
sorry to hear about your boost problem. wish i could help you, but i know nothing about turbos. =) i'm sure some of the gang here will have some ideas.
good luck!
Old Jun 29, 2008 | 04:55 PM
dublinoh's Avatar
dublinoh is infamous around these partsdublinoh is infamous around these parts
sounds like a boost leak...but I don't know much more than the last poster...
Old Jun 29, 2008 | 05:56 PM
OCTurbo's Avatar
OCTurbo is infamous around these parts
I had the same problem recently and had a loose boost hose and a cracked f hose (boost hose). What mods do you have (what is your normal boost)?
Old Jun 30, 2008 | 12:46 AM
boost
The car has k16/24 turbos,reflashed DME,remus exhaust and bmc filter...It runs 1,3-1,4 over and 1,1 stable boost pressure...It happened when i pressed the gas with 6th gear and the pressure went to 1,4...the car boosted then i lost power...
Old Jun 30, 2008 | 05:27 AM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
it's most likely a boost leak- jack the car up and look underneath where the hose connects the turbo to the intercooler....
1.4 bar of boost seems too high....
Old Jun 30, 2008 | 06:06 AM
madsex343's Avatar
madsex343 has a brilliant futuremadsex343 has a brilliant futuremadsex343 has a brilliant futuremadsex343 has a brilliant futuremadsex343 has a brilliant futuremadsex343 has a brilliant futuremadsex343 has a brilliant futuremadsex343 has a brilliant futuremadsex343 has a brilliant futuremadsex343 has a brilliant futuremadsex343 has a brilliant future
Mitsako, check the F-hose and the diverter valves! 99% there's your leak!
Old Jun 30, 2008 | 07:50 AM
wross996TT's Avatar
How do you know there are no codes? Get the codes read (you do not need to get an idiot light to have codes stored). There are possibilities....leak, TB shutdown.
Old Jun 30, 2008 | 08:36 AM
kostaki...the f hose is the one that is divided for the dump valves?I read the codes with my obd reader and there was nothing...Tomorrow I will try to fix it...
Old Jul 1, 2008 | 06:26 AM
Problem solved...The right wastegate axle was unbolted from the exhaust flap and so the turbo remained under no pressure...Easy and no cost repair...
Emre@Esmotor
Oct 19, 2015 12:06 PM
whtrabt
Oct 5, 2015 05:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
