Brembo BBK + OEM wheels = clearance issues?
Old Jul 4, 2008 | 05:14 AM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
Question Brembo BBK + OEM wheels = clearance issues?
I'm really considering upgrading my front brakes to the 14" 8 piston Brembo BBK kit as I'm beginning to track the car more and more. I'll be using Nitto NT01 DOT R-compound tires on my OEM wheels for track events so I'm wondering if I'll need spacers (if so, how big) to clear the front OEM wheels. My daily rims are 19" Cargraphics so I'm thinking they should be fine, right?
Old Jul 4, 2008 | 06:06 AM
Kaizu's Avatar
Kaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud of
Cargraphic wheels - even their 18" version - clear very big brakes.
Not sure about the stockers and Brembos. At least the stock Turbo wheels fit nicely the GT2 6-piston 350mm brakes which are also made by Brembo.
Old Jul 4, 2008 | 11:50 AM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
If you're going to use OEM turbo wheels, I would use the GT2 6 piston calipers with 997tt 14" rotors. They fit behind the 18" turbo wheels perfectly, and reduce brake fade. I'm very happy with mine.
Old Jul 4, 2008 | 01:46 PM
That's a potential option for me as well. What's the difference in weight between the 14" 6-piston Brembo BBK vs. the 14" GT2 6-pistion with the 997TT rotors???
Old Jul 4, 2008 | 02:32 PM
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
The Brembo 6 piston mono block kit with 350mm rotor will not fit under a stock 18, even with spacers. You need a wheel with an 18in barrel, like a BBS E88. Not sure about the 8 piston kit though. If you're not going to do enduro races stick with the 6 piston kit. It's cheapers, cools much better, is much lighter and brakes just as well or better than the 8 piston kit as long as you're not running enduros. Any 19in wheel will clear any 350mm kit. You might even be able to squeeze a 380mm kit in there.
That being said the 6 piston Porsche OEM kit will, of course, fit.
Old Jul 4, 2008 | 02:33 PM
CarNerd's Avatar
Caliper for caliper the Brembos are a slight bit lighter. The Brembo two piece floating rotor is quite a bit lighter than the OEM 997 Turbo rotor.
FWIW: The key to any of these systems is good fluid, lines and pads. I was never a fan of the stock pads, even Brembos.
Old Jul 4, 2008 | 02:50 PM
EVO KNIEVO's Avatar
EVO KNIEVO is infamous around these parts
if your actually serius about this call brembo race technologies in costa mesa california and have them email you the cad drawings of the kit. this is the first thing you should do. then you can measure your wheels to find out what fits (brembo tells you how to properly measure the wheels with a ruler.
Old Jul 4, 2008 | 03:00 PM
CarNerd's Avatar
No need. Take my advice. I've spoken with a Brembo advisor in person about this. Unless you're doing enduro races (more than an hour run time), the 8 piston system is useless (heavier and more expensive).
I can assure with 100% certainty the 6 piston kit will not fit under the stock 18 twist unless you go with a 320mm rotor, if they even offer that.
Old Jul 4, 2008 | 03:14 PM
EVO KNIEVO's Avatar
huh? brembo has advisors???? they have a sales rep's..... your comment about being useless un less doing endurance racing is garbage. proper cooling, pad material, rotor vain design AND MOST IMPORTANTLY THE TOTAL SURFACE AREA OF THE PISTONS (contact patch on the pad) makes the differences.
and dude, i dont know who you talked to (maybe a stop tech rep j/k) but the 8 piston calipers are a heck of allot lighter than ANY GT kit brembo makes 4 or 6 piston.
http://www.brembo.com/CatalogoRacing/2007/index.html
Old Jul 4, 2008 | 03:19 PM
EVO KNIEVO's Avatar
and i have brembo's gt 350mm 6 piston kit under a set of 18's.
Old Jul 4, 2008 | 03:31 PM
CarNerd's Avatar
Sorry Brembo sales rep. And from what he told me, the newer 6 piston monoblock kit has better cooling properties that the 8 piston kit (none GTR). Both run the same vain design.
If you're refering to the GT-R kit yes, extremely lighter. But i highly doubt we're talking about that kit as it run north of 12k.
Old Jul 4, 2008 | 03:38 PM
Kato's Avatar
Kato is just really niceKato is just really niceKato is just really niceKato is just really niceKato is just really nice
Evo,
Is that on your Porsche or another car? Are those Enkei's? If so, do you have some specs to share? (offsets, weight, price, where you got them?)
PM me if you prefer...
Thanks in advance!!
Old Jul 4, 2008 | 07:25 PM
EVO KNIEVO's Avatar
Originally Posted by Kato
Evo,
Thanks in advance!!
lolz, yeah there on one of my evos. not a p-car, i was just adding that because i know for a fact that you can get the the 350mm gt's under a set of 18's
but there 18x11's all around with a +12 off set
Old Jul 4, 2008 | 07:28 PM
EVO KNIEVO's Avatar
im sorry, i think your right. we were talking about two different kits. i didn't know there was a gt 8 piston kit. i was referring to the gt-r kit that is in fact north of 12k i believe that there actually 14k retail and about 10k with the homie hook up discount.
Old Jul 4, 2008 | 09:23 PM
vividracing's Avatar
Brembo 6piston monoblock 14inch kit DOES NOT fit under the stock turbo twist wheels. You can run the 6piston GT3 OEM brakes, those do.
