diagnostic help please
Old Jul 4, 2008 | 12:09 PM
Carter Beck's Avatar
Carter Beck is infamous around these parts
I have been having a misfire problem only when at higher revs and throttle. I changed the MAF. This improved the car's somewhat but still getting a CEL. My durametrics code reader is giving me:
P0410- secondary air too low on cylinders 1-3
And misfire codes for cyl 1-3
This seems like it is enough information to make a specific diagnosis but I don't have enough experience to pinpoint the problem. Any help here would be greatly appreciated.
Old Jul 4, 2008 | 12:17 PM
dublinoh's Avatar
dublinoh is infamous around these partsdublinoh is infamous around these parts
Is this just post #22? But seriously, maybe a list of mods, especially recent ones might help the more knowledgeable on the board help you. (wild guess MAF)
Old Jul 4, 2008 | 02:55 PM
ard's Avatar
ard
How many miles on the plugs? What kind? (ie are they stock or did someone change them once already)
Old Jul 4, 2008 | 05:04 PM
wross996TT's Avatar
cracked coil packs ...bad plugs.
Old Jul 4, 2008 | 09:25 PM
vividracing's Avatar
get the Denso IK22 plugs...
Old Jul 5, 2008 | 01:57 AM
thanks for the input guys. really i don't know how many miles on the plugs. dealer said they were changed before i bought the car used, porsche certified with 28k miles on her, but i doubt it. after the MAF, plugs are next. Given the geat spark plug debate, i am hesitating. dealer sent me a set of the beru's but am leaning bosche fr6, or maybe the denso's. ???????? not looking forward to the project but its next. a bit bothered by the fact that its all on one bank.
2002 996tt tip, fvd flash, evo DV's, BMC filter
Old Jul 5, 2008 | 06:22 AM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
Invest a couple hundred dollars in a scanner and see what your sensors are doing at high rpms. It may eliminate the guess work.
Old Jul 6, 2008 | 07:44 PM
here is the follow up for the record. spent all afternoon changing the plugs. what a pain in the ***! but the problem seems to be solved! no damn CEL flashing in my face. based on research and local availability i went with NGT iridium plugs. first test drive blew a boost hose that wasn't seated properly. reset with a quick battery disconnect. snapped the boost hose back in and i am up and running. life with no CEL, hurray!
Old Jul 6, 2008 | 07:46 PM
here is the follow up for the record. spent all afternoon changing the plugs. what a pain in the ***! but the problem seems to be solved! no damn CEL flashing in my face. based on research and local availability i went with NGT iridium plugs gapped to .028in. first test drive blew a boost hose that wasn't seated properly. reset with a quick battery disconnect. snapped the boost hose back in and i am up and running. life with no CEL, hurray!
Old Jul 7, 2008 | 09:19 AM
Glad you got it fixed! Plugs make all the difference in these cars.
Old Jul 7, 2008 | 10:11 AM
Dan,
what do you think of that plug for a stage one or two car? I went with what was available on sunday (poor planning).
Old Jul 7, 2008 | 11:43 AM
hey if it works it works I use the Denso in our cars. But probably similar http://www.vividracing.com/catalog/d...5-p-28441.html
