Help! SSK install
B&M SSK
Do you guys with the in-car SSK notice/mind the 1/4 inch forward/backward play with the shifter while in gear? I cranked the nut on the front of the shifter as much as possible but can't seem to eliminate the last little bit of travel.
Thoughts?
Thoughts?
when I did it myself with the shifter out, I had to use a soft mallet to get everything to seat well. I have had no problems with my porsche ssk (read: same as b&m but the porsche name came at a premium). In order to fix this you may have to remove things again.
good success
good success
Re: B&M SSK
Thoughts?
Thoughts?
sdg1871
Sep 12, 2015 06:54 AM
