Just got this code can anyone tell me what it means?
Old Jul 13, 2008 | 07:54 PM
lennyspoolin's Avatar
lennyspoolin is infamous around these parts
P1108 porsche fault code 358 oxygen sensor adaptation lower load range bank 2
I erased the code but then when i went to start the car it would barly stay on it was idling realy rough and blake smoke was coming out the exsaust for about 5 sec and then it cleared up i didnt want to drive for i fear that i may cause some damage. Any ideas what is causing this?
Old Jul 13, 2008 | 08:17 PM
wross996TT's Avatar
P1108 Oxygen Sensing Adaptation, Lower Load Range, Bank
2 – Below Limit
Possible fault cause
♦ Incorrect signal from MAF sensor
♦ Fuel pressure too high
♦ Fuel injector leaking
my guess MAF...
Old Jul 13, 2008 | 08:37 PM
Well my car has been running rich. My air fuel ratio gauge sometime stays at 9.3 at full throttle i have a 5 bar fuel reg installed with 65 lbs injecters could this be the problem
Old Jul 13, 2008 | 08:38 PM
some one had sugested to change the fuel reg
Old Jul 13, 2008 | 08:44 PM
Hay WROSS who makes that wing thats on your car and did it just bolt on to the stock wing lifts?
Old Jul 13, 2008 | 09:07 PM
wross996TT's Avatar
Strosek and yes...fuel problem...could be
Old Jul 13, 2008 | 09:30 PM
Is their a web site for that wing
Old Jul 13, 2008 | 09:38 PM
wross996TT's Avatar
I got it 4 years ago in a group buy from Eric @bumperplugs....
Old Jul 13, 2008 | 09:51 PM
Thanks Wross. So do you think if i were to go to a smaler fuel reg that might help out my car from running rich!
Old Jul 13, 2008 | 10:42 PM
wross996TT's Avatar
Not sure the fuel problem is that easy....could be your injectors went bad. Doubt it is the FPR, but that would be after injectors.
Old Jul 13, 2008 | 10:55 PM
ard's Avatar
ard
What does RPM say??
Bmw M3 Guy
Feb 21, 2018 09:29 AM
E55 Bulldog K2
Dec 15, 2015 08:38 PM
kkswow12
964
Sep 11, 2015 10:31 PM
Yogi911
Sep 9, 2015 08:20 PM
