Plastic air flow regulator Pre MAF
I will however say that:
1. the boost drop off after peak gives me a concern
2. 1.2 is still within the efficiency range of a K24, so unless there are fueling or other issues, 1.2 on pump isn't an issue in and of itself; and
3. I run a sustained 1.1-1.2 bar on 93 octane on my K16/16gs without any problems.
The video you posted is 4th does 3rd boost the same way inmediatelly to 1,1- 1,2?
I can pull my gates 1 mm more to see if I can get the 1,2 on third , But I do see 1,2 on 4 th on some peak...
To be clear, that is not my car, but someone with the similar tune. Mine pulls like that in about any gear. Spikes don't mean anything....it is what you can sustain.
I have clear sustained 1,1 on all gears and I think I can pull no problem the gates more to reach the 1,2 (just 1mm more on the gates for sure and I am there), the question is... Is it safe just with the 5 FPR for the fuel part?
tropicatango
Jun 8, 2025 01:00 PM
Jul 29, 2019 11:13 AM
Jun 10, 2017 07:45 PM
nlakind
Nov 6, 2015 10:15 AM
