clutch problem?
Old Jul 21, 2008 | 04:21 PM
OCTurbo's Avatar
OCTurbo is infamous around these parts
clutch problem?
On initial start up each day the clutch is very heavy when i push it to the floor. After that it is fine. All subsequent start-ups throughout the day are fine and the clutch does not slip. The clutch is stock and my car has 30k miles. Any thoughts.
thanks.
Old Jul 21, 2008 | 04:51 PM
wross996TT's Avatar
Accumulator...and slave. Do a search.
Old Jul 21, 2008 | 05:25 PM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
Do both at one time...and if you need a new clutch anyway, same labor.
+1 on the search. NOT a simple at home job.....lift is a very valuable thing, etc.
JB
Old Jul 21, 2008 | 06:49 PM
adeeois's Avatar
adeeois is infamous around these parts
thanks.
Diddo on the accumulator, had one go out in May, @ 38K.
Had to pull the trans at the same time (shifting problem) and found the clutch to still be in good condition. Went to Sachs Motorsport PP & disk any way. My guess is since you are stock and if you are not doing hard launches, you don't need a clutch yet. Besides it's a bit of a job with a trick or two, best left for an experienced mechanic with a lift.
Old Jul 22, 2008 | 08:02 PM
OCTurbo's Avatar
thanks for the replies. For those of you that had to replace your clutch accumulator, how long did it take from the first time you noticed it was a problem until it had to be replaced? Right now mine is not bad- just a little heavy when i first start up.
Old Jul 22, 2008 | 08:31 PM
Me, about 3 weeks.
Old Jul 22, 2008 | 09:22 PM
adeeois's Avatar
3-4 weeks.
Old Jul 23, 2008 | 10:53 AM
WOODTSTER's Avatar
I just had exact same problem.
It is the accumulator (shaped like a ball, also get a small washer and some
pentosin as the power steering fluid feeds it). Parts were about $185.
Good luck,
MK
Old Jul 23, 2008 | 06:49 PM
ttboost's Avatar
Mine is in shop right now for crappy pedal feel. I still have a few months left on the warranty so...The dealer will cover the slave, NOT the accumulator ($200?), plus a $140 "diagnosis" fee.
jaehoppa
Oct 22, 2015 09:17 PM
oo7
Sep 10, 2015 08:08 AM
falter
964 Turbo
Sep 4, 2015 01:41 PM
falter
964 Turbo
Sep 4, 2015 01:37 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
