key stuck
Old Aug 3, 2008 | 04:12 PM
marco3's Avatar
marco3 is infamous around these parts
key stuck
My key is stuck in ignition of my '02 996Turbo. Car still runs but headlights and ac don't work. Any suggestions. Car was valeted before this happened.
Old Aug 3, 2008 | 04:52 PM
wross996TT's Avatar
First i assume you tried rotating the steering wheel back and forth then you may need a new ignition switch
Old Aug 4, 2008 | 12:31 AM
marco3's Avatar
You assumed correctly. Thanks for the insight, hopefully it is just an ignition switch. Will find out today.
Old Aug 4, 2008 | 07:39 AM
WOODTSTER's Avatar
They do go bad, mine would rotate around in circles occasionally.
I had mine replaced. Easy fix.
MK
Old Aug 4, 2008 | 10:02 AM
DaveMo's Avatar
DaveMo is infamous around these partsDaveMo is infamous around these parts
We had this happen to friend on his 996. A failed ignition switch is not an unusual problem. There is a locking pin that pops out and holds the key on. He used a small screwdrive to push it in and pull the key out, but you may want to get it to the dealer first - otherwise your ability to steer the car will be impacted.
Old Aug 5, 2008 | 12:34 AM
marco3's Avatar
Thanks, guys, you were right. Dealer handled it for $430 out the door. I could have probably had it done cheaper, but I can't stand being without the car for too long.
Bmw M3 Guy
Feb 21, 2018 09:29 AM
airbusdrvr
Dec 27, 2015 07:43 PM
allroadusa
Sep 25, 2015 10:57 PM
kensilver
Sep 17, 2015 04:03 PM
lokmeup
Sep 9, 2015 09:24 PM
