AWE DV's Problem..
Old Aug 15, 2008 | 07:01 AM
bavboym3's Avatar
bavboym3 is infamous around these parts
AWE DV's Problem..
I installed my new DV's yesterday. Now I am getting a higher idle, and im only hitting .6-.7 boost... I was hitting .9 before I put them in.
I am wondering if I didnt tighten something enough, or I mixed something up.. Any idea?
Old Aug 15, 2008 | 07:04 AM
bavboym3's Avatar
I switched from the stock clamps that you have to open up, to fasteners that you have to tighten with a screwdriver... I am wondering if this may have been a bad idea.
Old Aug 15, 2008 | 07:11 AM
Brian@Performance Outfitters's Avatar
Brian@Performance Outfitters is just really niceBrian@Performance Outfitters is just really niceBrian@Performance Outfitters is just really niceBrian@Performance Outfitters is just really nice
Sounds like a leak somewhere to me. Are they the Bailey valves?
Brian
Old Aug 15, 2008 | 07:15 AM
bavboym3's Avatar
This is how I did both DV's
bavboym3's Avatar
Brian
Yes.. I bought them used off a fellow member.
Old Aug 15, 2008 | 09:24 AM
oak's Avatar
oak
did you buy them from usctrojanman?
Old Aug 15, 2008 | 09:43 AM
bavboym3's Avatar
No I got them from..
09:45 AM unvmym3
Old Aug 15, 2008 | 10:07 AM
colorinc's Avatar
colorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond repute
look for a crack in the f hose... the f hose may be loose or not properly sealed on the intake..... remove diverters apply vacuum to the diverter nipple on top and see if the piston is accuating properly
this is what i would look for
t
Old Aug 15, 2008 | 10:09 AM
Josh/AWE's Avatar
t
Great advice.....
Higher idle is usually caused by a vacuum leak somewhere.
Old Aug 15, 2008 | 10:16 AM
colorinc's Avatar
a vacuum leak.... after the throttle body will result in higher idle
Originally Posted by Mike/A.W.E.
Great advice.....
Old Aug 15, 2008 | 10:21 AM
colorinc's Avatar
if a higher idle is happening look for something out of place or off/cracked on the hoses that go to the top of the diverter.... the one that sets toward the firewall is a tough one to install and maybe the hose slipped off or cracked
tim
Old Aug 15, 2008 | 10:22 AM
colorinc's Avatar
+1 mike
Great advice.....
Old Aug 15, 2008 | 10:57 AM
bavboym3's Avatar
I just found the top of my Y pipe looks loose. I am going to try to pin that down
Old Aug 15, 2008 | 10:59 AM
bavboym3's Avatar
Where is the dle supposed to be at? Mine is at about 900ish right now
Old Aug 15, 2008 | 11:00 AM
bavboym3's Avatar
Ater I tighten the Y pipe I am going t see how it drives.. If this doesnt fix it.. I am going to break down the DV's and check all connections.
