people that blew engines? how did it happen. under what conditions?
Id love to hear about the guys on the forums, past or present, that blew anything related to the stock engine, that required an expensive rebuild. rods, pistons, bottom end.. whatever.
Im assuming many people wont come forward, but i think its best from us to learn from the past and have this documented so it can be prevented.
All info regarding tune, modifications, estimated power level, weather conditions, where it happened (i.e DE event, street, texas mile etc) what you think might have been the culprit, in what gear and rpms etc... i guess the more stories we hear the more usefull it would be.
I don't understand,why do rods bent with oem fuel system ?
Do you mean when you're running lean rods can bent?
I'm asking because I had a melted exhaust valve and the rod was also bent but my porsche mechanic didn't understand why the rod was bent because there was no damage at the piston....
we all heard and know of many more but, obviously, many people are reluctant to post since that gives the tuner a bad name.... however i feel like we should post, since we can learn from those experiences...
the killer combo for me: was cold air 40F ambient air temp, pump gas with torco accelerator(i only run sunoco gt plus now) and 1.35 bar.... at that time i was running just the 5bar and stock injecors
tim
tim
colorinc.. thanks for coming forward...
so in your case it was clearly too much boost on pump gas... right?
marty/air
yes...IMHO fuel is everything when you get above 1.1 bar and yes using pump gas with the torco stuff+1.35+cold ambient air temp killed my engine... i think if i was running true 104/105 oct i would have been alright
tim
tim
Tim,
Have you heard for sure that corrosion is a byproduct of the meth injection? I have heard that it's not true and that any engine that has run meth that has been taken apart is spotless and clean in the Heads and combustion chambers with no carbon buildup. No mention of corrosion.
The aspect that really concerns me is if the system fails for any reason, you must have immediate warning, so that you don't go boosting at WOT without the meth system doing it's job. A proper system should alert the driver if power to the meth pump fails, pressure in the meth lines drops, the meth tank is low, meth nozzles clog, etc.
Tim,
as for the meth fail safe systems i was checking out snow performance they have a real nice product with a couple of real neat fail safe options check them out http://www.snowperformance.net/products.php?p_cat=324
tim
Tim,
Don't feel sorry for the confusion - it's good information and warrants evaluation. The last thing any of us wants is to unknowingly ruin one of our engines. I'd like to hear what Tony(EPL) has to say about the corrosion issue, as he has experience with these systems and should know. I'm thinking about this as a possible next power upgrade, but I would like to learn a little more about it first. I like the idea of just filling up a small tank with some windshield washer fluid and being able to run the equivilent of race gas all the time. Even just the advanced timing it allows at moderate boost would be a nice.
