my race clutch feels mushy.can this be changed?
Old Aug 17, 2004 | 12:47 PM
phillym5's Avatar
phillym5 is a splendid one to beholdphillym5 is a splendid one to beholdphillym5 is a splendid one to beholdphillym5 is a splendid one to beholdphillym5 is a splendid one to beholdphillym5 is a splendid one to beholdphillym5 is a splendid one to behold
i just installed a Sachs race engineering clutch, and lightwieght flywheel. My problem is the clutch pedal didnt really change. Is there a way to get it nice and stiff. I prefer a hard clutch pedal. Can you possibly change the "clutch assist"?
Im just so used to driving a hard clutch. I am happy with the flywheel and the "Grabbing" factor of the clutch. I just need some pressure on the pedal.
thanks,
josh.
Old Aug 18, 2004 | 12:51 AM
FAST3's Avatar
FAST3 is infamous around these parts
Josh ..
I wish I had an answer for you on this post.
Old Aug 18, 2004 | 02:24 AM
phillym5's Avatar
anyone?
Old Aug 18, 2004 | 06:25 AM
Porsche Tech's Avatar
Porsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nice
So you're just looking for more pedal FEEL? Ouside of replacing the stock brake system with Tilton dual master cyl set up i can't think of any other way to change the pedal feel and that would render your stock system useless as far as electronic control. Maybe it is possible with enough research to find a master cyl w/ same outter dimensions but different piston size. Why do you want more feel if what you have is totally functional? In driving events or racing the heavier pedal resistance just wears on you after an hour and a half in the seat- same when stuck in stop and go.
Old Aug 18, 2004 | 07:34 AM
KJM3's Avatar
KJM3 is infamous around these parts
How does replacing the BRAKE system fix his CLUTCH feel?
- KJ
Old Aug 18, 2004 | 07:57 AM
phillym5's Avatar
well, ive been using a stage 3 or 4 race clutch in the M5. It is real hard. I love it and am totally used to it. Even in chicago traffic. It is really hard for me to use a soft pedal. Just trying to find out what my options are. I seem to slip the porsche clutch more due to the long travel of the pedal. The clutch in the M5 im using is a Sachs Race Engineer clutch, just like the on i put in the Turbo. The feel is just not there. thanks anyway,
josh.
Old Aug 18, 2004 | 08:57 PM
Sloth's Avatar
Sloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud of
The GT2 clutch has more feel (stiffer) than the TT clutch. Anybody know what makes the difference between the GT2 and TT? Is it just the clutch or is there more?
Old Aug 18, 2004 | 09:03 PM
PorschePhd's Avatar
The clutch system is hydraulic and power assisted from the power steering pump. So it is hard to make the pedal stiffer as the system is like your brakes, they are power assist. Little more complicated then just swapping something out.
Old Aug 18, 2004 | 10:35 PM
cjv's Avatar
cjv
Moderator
S Car Go removed the hydraulic power assist unit when they installed the Tilton clutch. The Tilton set up has very good clutch feel.
Old Aug 19, 2004 | 03:52 AM
phillym5's Avatar
Any idea on it being feesable with my clutch set up? what does the Tilton set up consist of? I guess the hardest part to deal with would be the travel of the clutch before it engages. Brand new clutch, and doesnt engage until half way up. Wierd.
josh.
Old Aug 19, 2004 | 04:48 AM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
josh.
You're at half way?....how did you get that, I'm at 2/3s
I like the Sachs set-up.......but no, has nothing to do with travel and feel (it just bites a tad).
The amount of hydraulic assist (and travel) Pcar dialed into the Turbo was over the top.
Old Aug 19, 2004 | 07:24 AM
phillym5's Avatar
ok. ill just learn to appreciate it for what it is.
thanks guys.
josh.
Old Aug 19, 2004 | 11:19 PM
FAST3's Avatar
You still hate it .. j/k
COBB Tuning
Jan 1, 2025 09:02 AM
00aston
Aug 27, 2015 12:01 AM
JMon
Aug 21, 2015 08:20 AM
