clutch pedal noise
clutch pedal noise
I am getting a grinding creaking noise by the slave cylinder (i.e. needing lubrication) when I step and release the clutch pedal. Is there anything I can lubricate to stop the noise. Thanks
I had the same problem, wasnt the slave cylinder but the clutch spring behind the pedal.
made a slight squeek noise every time it was being pushed in/out
My friend fixed it in 1.5 hours..part was $100 and it was fixed from behind the pedal.
make sure its not that first
