Not Charging Light Came On This Morning
Old Oct 26, 2008 | 01:06 PM
Sker66's Avatar
Sker66 is a glorious beacon of lightSker66 is a glorious beacon of lightSker66 is a glorious beacon of lightSker66 is a glorious beacon of lightSker66 is a glorious beacon of light
MY NOT CHARGING LIGHT CAME ON THIS MORNING AFTER AN ACCELLERATION RUN UP TO REDLINE.
I STARTED TO DRIVE BACK TO MY HOME AND YOU COULD SEE THE VOLT METER SLOWLY GOING DOWN TO 10 VOLTS WHERE THE MOTOR JUST SHUT OFF AFTER GETTING SOME ABS AND PASM WARNINGS.
MY FIRST GUESS IS THAT A ALTERNATOR BELT CAME OFF.
WHATS THE BEST WAY TO GET TO THE BELT?
ANYONE HAVE ANY SIMALAR ISSUES?
THIS TT ONLY HAS 24K MILES, BATTERY IS NEW.
Old Oct 26, 2008 | 04:40 PM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
did you lose power steering and the car overheat as well? the best way to get to the belt is open the rear lid and remove the airbox, but if the belt came off, there would be some other signs that it did indeed come off, but hell you can still see the belt if it was on or not just by looking..... either in the engine compartment or from beneath the car.
Old Oct 26, 2008 | 05:04 PM
Sker66's Avatar
Just Started Doing Some Checks This Afternoon.
Belt Is On And Ok And Looks Fine With Car Running.
I Will Proceed With Some Ac Output Tests.
Previous Ownerhad Just Installed An 800 Watt Stereo Which I Fear Is Putting A Tremendous Strain On The Alternator.
Plus There Are Times When Weeks Goes By And I Find A Low Battery When I Try To Start. Possible Current Draw From Stereo Installation.
Battery Is New.
Old Oct 26, 2008 | 05:12 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
Could be the alternator going bad.... I just replaced the one on my 02 with around 30k miles...
Old Oct 26, 2008 | 05:38 PM
Sker66's Avatar
WOW!..........CAN'T BELEIVE THESE ALTS GIVE OUT SO EASILY. WHAT HAPPENED TO THE GERMAN "BULLIT PROOF ENGINEERING" ?
JUST GOT BACK FROM THE GARAGE AND FOUND THAT I AM GETTING A METER READING AT THE BATTERY OF 12.3 VOLTS BEFORE STARTUP AND 11 VILTS WITH CAR RUNNING.
NineNineSixTT..........where did u buy your new alt. and for what $$
Old Oct 26, 2008 | 05:39 PM
Sker66's Avatar
Vilts Is Volts In German............
Old Oct 26, 2008 | 06:48 PM
AIRjordan23's Avatar
AIRjordan23 is infamous around these parts
my alternator gave out at 30k miles...
i noticed the volt guage drop from the usual 13.5ish to under 10. once it goes below 12 you get alot of errors (psm, abs, airbags etc).
i had it covered under cpo.. dealer charges 1k for it..roughly...
Also...you can have a big current draw..however sounds like its the alternator thats your issue..
Old Oct 26, 2008 | 07:17 PM
Sker66's Avatar
now i'm wondering if the high watt stereo is also putting too large of a load on the stock alt.
Does anyone know of a higher output alt that will fit these cars?
or maybe i need to yank the stereo.
Old Oct 26, 2008 | 07:47 PM
Porsche917's Avatar
that german bulletproof generator is most likely nippon denso lol
Old Oct 26, 2008 | 07:48 PM
jimq's Avatar
jimq is infamous around these parts
my alt went out at 65K miles on my 03. It was CPO so dont know the cost. It did the same as you said. Volts dropped then finally shut off.
Old Oct 26, 2008 | 07:52 PM
I had a ~800 watt system in my car.
I paid ~ $300 for an alternator from http://www.autopartswarehouse.com/
I did the swap myself; took about 3-4 hours.
There's a very useful DIY floating around...
Old Oct 27, 2008 | 06:30 AM
Sker66's Avatar
Did You Take Off Yout 'y' Manifold Going Into The Throttle Body Or Were You Able To Leave It In Place?
COBB Tuning
Jan 1, 2025 09:02 AM
GSR Autosport
Aug 26, 2015 05:20 PM
BauerR
Aug 24, 2015 12:43 PM
richard2966
Bentley
Aug 22, 2015 03:33 PM
Nissan GTR
Aug 19, 2015 02:11 PM
