996GT2 PCCB - problem? Please help
Old Nov 7, 2008 | 01:00 PM
TwinT's Avatar
TwinT is infamous around these parts
Hello All!
My brakes seem to be making a new noise, they can sometimes be squeaky however they are now making a more squeaky, almost grinding noise at low speed braking and traffic braking.
The noise seems to resound in the cabin.
I have checked the pads but they seem to have loads of life.
Any ideas?
Lee
Old Nov 7, 2008 | 01:17 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Just not using them hard enough
Old Nov 7, 2008 | 01:19 PM
TwinT's Avatar
Thanks Steve, your probably right lately.
Went to brands on Wednesday but took the CSL to get a feel for it.
Old Nov 7, 2008 | 01:29 PM
Yip... sure I read that!
Honestly though... I really don't know about the Carbons... I wonder if it is just not getting heat into them.
Old Nov 7, 2008 | 08:37 PM
superchicken's Avatar
superchicken is infamous around these parts
The rotor surface looks good to me. Mine squeak a little. Look at the inside of the rotor to make sure there is not part of caliper rubbing on disc. I presume it only makes this noise when you apply the brakes? I hear/feel light buzz with moderate braking. Figured it was the holes in the rotor impacting pads. Probably nothing to worry.
Old Nov 8, 2008 | 08:15 AM
TwinT's Avatar
Thanks.
Yes only under braking, I can feel it also.
Very strange.
Old Nov 8, 2008 | 09:07 AM
t2_996420's Avatar
t2_996420 is infamous around these partst2_996420 is infamous around these parts
What year is your GT-2??
Old Nov 8, 2008 | 09:24 AM
TwinT's Avatar
2002, however I do not think that these are the original set of discs on the car.
Apparently the last owner had them replaced.
Old Nov 8, 2008 | 09:26 AM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Your rotors & brake pads look perfect. My car does the same every once in a while.Just wash the build up of brake dust out every so often.
Old Nov 8, 2008 | 09:33 AM
TwinT's Avatar
Thanks Paulie, Im going to get the fluid changed too.
My concern was that I did not want to drive it if the pads were too worn.
Old Nov 8, 2008 | 09:36 AM
I have heard if you change them at about 60% wear you will not have any rotor problems.I'm not sure if this is true but thats what I have heard.
I-Man
Sep 17, 2015 05:31 AM
Alankey
Sep 16, 2015 08:25 AM
spooltime
Cayenne Turbo
Sep 12, 2015 12:05 PM
Nuke
Sep 8, 2015 09:09 AM
TheInfamousDrew
Sep 6, 2015 10:16 AM
