100 cel vs 200 cel cats
Old Nov 22, 2008 | 03:31 PM
Prche951's Avatar
Ok, I have ended up with two sets of cats. One set is the fabspeed 200 cel cats. The other set are the German made 100 cel cats that fabspeed had on their gen 1 exhaust. I am currently running the 200's. I am keeping one set not both, so I am wondering if it is worth it to switch out the 200's for the 100's. These 100's have fill that looks almost new, and I am sure they flow more, but I am at the limit of noise. Has anyone done this...opinions?
Old Nov 22, 2008 | 05:45 PM
WOODTSTER's Avatar
more flow is always better and I do not believe (educated guess) that the
difference in noise between one type of cat and another will make much difference.
Go with the 100's (or preferrably no cats)
Good luck!
MK
Old Nov 22, 2008 | 08:03 PM
Prche951's Avatar
Good luck!
MK
If I punch out the fill in the cats does it cause a cel light to go off?
Old Nov 22, 2008 | 08:29 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
More than likely, yes you will get a CEL if there is no "catalyst" material, or a bypass of material.
Old Nov 22, 2008 | 09:13 PM
Prche951's Avatar
Have you seen a lot of cel issues with 100 cel cats?
Old Nov 22, 2008 | 09:15 PM
Very few. Have seen a few issues with some of Fabspeed's earlier 100 cell cats, and there is a loud 997S in the area that has what is believed to be a PSI exhaust, with CEL from lack of efficient cats.
Old Nov 22, 2008 | 09:19 PM
colorinc's Avatar
colorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond repute
i ran 100 cell cats with no cel... i would punch them out (the performance gain is huge!)and have your programer shut off the down stream 02 sensors
tim
Old Nov 22, 2008 | 09:31 PM
Prche951's Avatar
tim
at your power level I can see that being the case, but I am quite a bit under your power level. I already have a straight through exhaust. Too bad there is no hp comparison between cats. Maybe there, but I have not seen it.
Old Nov 22, 2008 | 09:36 PM
colorinc's Avatar
tru... i would use the less restrictive cats.. who's tune are u using?
Old Nov 22, 2008 | 09:43 PM
Prche951's Avatar
UMW stage2
Stuart@VelocityAP
Sep 1, 2021 02:04 PM
PenguiN
Apr 22, 2021 07:33 PM
cm09578
Sep 22, 2015 06:07 AM
shifter_
Sep 8, 2015 12:07 PM
oddjob142
Aug 19, 2015 12:27 PM
