Simple Coolant question....
Old Nov 23, 2008 | 11:11 AM
BlueRanger's Avatar
BlueRanger is infamous around these parts
I tried to search but could not find.....
I just need a Coolant Brand and Water Mix Ratio (if needed) to top-off coolant tank.
Thanks!
Old Nov 23, 2008 | 11:56 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
If it's just to top off... use water... this will be fine!
Old Nov 23, 2008 | 12:01 PM
It's normally a 50/50 mix... you can run 60/40 etc. The coolant also provides a lubrication for the water pump. I just use the standard OEM coolant (Pink Color)... here in UK it's pretty expensive... I know others that have used the Audi version (different Color) to save some cash without any issues.
Old Nov 23, 2008 | 12:28 PM
BlueRanger's Avatar
Thanks for the responses...
Distilled water for topping off OK?
Any mainstream Coolant brands?
Old Nov 24, 2008 | 05:35 AM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
you should defintely stick with porsche oem brand or like steve says, maybe audi
Old Nov 24, 2008 | 07:04 AM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
Porsche coolant is $28/gallon and is to be mixed 50/50. That's $14 per gallon into the car.....not that bad......
Old Nov 24, 2008 | 07:49 AM
angldrkns9's Avatar
wait, just to confirm the coolant you pickup at the dealer isn't already 50/50 mixed?
my local dealer wants almost 40 bucks a gallon, luckily we have suncoast as a sponsor who sells it for much less =D
Old Nov 24, 2008 | 08:05 AM
PorschePhd's Avatar
The dealer coolant is the ONLY coolant you should use. There are things lacking in the other coolant that will cse issues with the Porsche system in time. You need to confirm with the dealer if their coolant is mixed. The Porsche stuff normally is.
Glasgo
Nov 30, 2015 02:37 PM
freddiemac
Oct 7, 2015 11:05 AM
Oct 6, 2015 06:13 PM
flewis763
Oct 4, 2015 04:14 PM
