not seeing enough boost... .6 Bar max :(
Old Dec 6, 2008 | 07:47 AM
  #31
996TTSCAB's Avatar
996TTSCAB is infamous around these parts
Funny as hell....
Old Dec 7, 2008 | 06:58 PM
  #32
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Back on topic....
I still am getting this intermittent low boost/high boost thing.... one minute I max out at .6 bar, then under same conditions soon after, it will hit 1.0 - 1.1 bar. This has happened 2 or 3 times now in the past week. Maybe disconnecting the battery that day really didn't do anything?
Anyone else ever have this happen?
Old Dec 7, 2008 | 07:05 PM
  #33
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
Any PSM / ABS lights?
Old Dec 7, 2008 | 07:07 PM
  #34
flash68's Avatar
Nope. not since I replaced that wiring harness and the stock MAF.
Occasionally it has been running a little rougher lately, but it isn't very often. And I have about 10k miles on the plugs.
Old Dec 7, 2008 | 07:33 PM
  #35
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Originally Posted by flash68
Back on topic....
This is *EXACTLY* the same symptoms I had, including the intermittent behavior, when I had a bad DV. See my earlier post in this thread.
They are a PITA to get in and out. You can test them for leaks by removing the vacuum line on top and putting some suction on them. I used a brake bleeder hand vacuum pump. If the vacuum bleeds off, you have a leaky DV.
Jon
Old Dec 7, 2008 | 07:52 PM
  #36
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Just sent you a PM Dave. Give me a call.
Old Dec 7, 2008 | 10:05 PM
  #37
flash68's Avatar
Jon
Hmmm.... I looked at your previous post re this. You mentioned colder weather could be the culprit. Well, it has gotten colder (for here) lately. Was in the high 40s last night for the first time this year.
I am hoping I can just struggle through this little nuisances I have been having lately til I decided on a turbo kit - GT660, k24/18g, hybrid of some kind?
Is it dangerous to keep driving my car with a potentially leaky DV? Are these things known/prone to just go bad?
thanks
Old Dec 8, 2008 | 12:50 AM
  #38
thanks
when it gets cold some ecus freak out the maf... and or the car boost a lot more and the ecu pulls timing back and or puts the car into limp mode.
Ill have something ready soon... stay tuned.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 8, 2008 | 12:55 AM
  #39
flash68's Avatar
Mark, I have no patience. Sending you a PM now!
Old Dec 8, 2008 | 02:00 PM
  #40
imolafem's Avatar
imolafem is a jewel in the roughimolafem is a jewel in the roughimolafem is a jewel in the roughimolafem is a jewel in the rough
you reset the ecu .... but like I said it may happen again.. you proabbly aboosting close to 1.3 bars just not seeing it on the dash.... and giac flashes protect the car from blowing up.... well they have the stock 1.3 bar safety in tact....
do you have stock wgs?
Would there be a fuse to pull to reset the ECU easier than disconnecting the battery?
Old Dec 8, 2008 | 06:47 PM
  #41
FAST FWD's Avatar
thanks
Yes, they are known to go bad. You are almost certainly going to replace them when you upgrade the turbos anyway, why wait? It isn't that hard to test them. Look at the photos below. Remove the hose at the top of the diverter valve, then pull a vacuum using a brake bleeder like the one shown in the second picture. You can get one at AutoZone. Test both of them. The one in back is harder to get to.
If they both hold vacuum, then this may not be your problem. But I'd be willing to bet it is. No disrespect to the guys who are blaming this on flaky ECU, but this is a much more likely explanation.
Jon
Old Dec 9, 2008 | 12:34 AM
  #42
flash68's Avatar
Jon
Thanks for the pics. Although I am very mechanically UNinclined, I will give it a shot!
Although my car ran great all day today for about 80 miles and in 45-55 degree weather.
Rguy
Apr 12, 2020 11:11 PM
VID997
97
Mar 20, 2018 02:23 PM
Myclue
17
May 19, 2016 11:14 AM
Fadi
Oct 5, 2015 12:14 AM
AdamNoone
Sep 3, 2015 04:15 PM
