my abs box is out :(
Old Dec 2, 2008 | 12:28 PM
vince_1972's Avatar
vince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nice
hi,
my ABS box is out and i'm searching a second hand to replace it because a new is very expensive and nothing in my country...
Can you help me? The part number is 996 355 755 63
Thanks!!
Vincent
Old Dec 2, 2008 | 03:38 PM
VAGscum's Avatar
Check with Module master or BBA for a rebuilt module. That should be cheaper.
Old Dec 2, 2008 | 08:58 PM
Chris Green's Avatar
Chris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond repute
What codes are you getting? are you 100% the box is bad, its pretty rare on these cars.
Old Dec 2, 2008 | 09:19 PM
PorschePhd's Avatar
Not as rare as you would think we have had a couple. You will also need a PIWIS to program it or take it to the dealer. It is not a plug and play replacement.
Old Dec 2, 2008 | 10:39 PM
ard's Avatar
ard
Is it actual 'progamming' or just opening/closing valves to completely bleed/purge? Just curious.
A
Old Dec 3, 2008 | 01:08 AM
vince_1972's Avatar
in fact, I rolled and d' only one blow I n' had more brake. After disassembling and checking of the part, it s' prove qu' there is an escape in l' cast solid hydraulic element and the liquid leaves by a depression. No part d' occasion in Europe and this part costs approximately 4000 dollars
Old Dec 3, 2008 | 01:43 AM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
I agree. Please tell us what the diagnosis/codes are, and if other things were checked first. I was told recently I needed to pony up $2800 for this box and I said whoa there. Let's back up a minute. Replaced a $120 wiring harness and that solved my problem.
Wondering if yours is similar.... hopefully you really don't need a new box.
Old Dec 3, 2008 | 01:59 AM
vince_1972's Avatar
c' is with l' interior of the block and it n' working because is not cut in the mass
It's not a eletronic problem
Old Dec 3, 2008 | 07:22 AM
PorschePhd's Avatar
A
It is actually programmed. You have to put in several series of codes. All the info is in the old one and then re-enter the new one The bad part is you can not always copy the info depending on what the box is doing and have to manually enter the codes.
Then you have to manually bleed it.
dgreen78
Cayenne 955/957
Sep 12, 2015 11:44 AM
iammulva
Sep 7, 2015 03:06 PM
