Headers on 996 TT worth it?
I ported mine myself and had a local shop...(Process coatings) ceramic coat the externals for $150. They came out great. I must say if you are going to do the porting yourself set aside plenty of time
How much hp are you running?
and yes i think they do make a decent amount of a difference , i loved mine but moved to a external wastegate set up so i had to swap. or else i would of never sold them.
I would agree in saying that headers really make a difference for the larger turbos. When it comes to moving exhaust gas, you do want a certain runner and collector style to help spool the turbo up and be most efficient. Generally, headers on a stock K16 or K24 car might yield 8hp. On a 500HP car not that big of difference. However as you put the puzzle together, the addition will make sense. Remember that also Peak HP is not as important to some drivers as is the the low end torque gain or mid range RPM improvements for those road racing. I can say that adding headers will slightly change the exhaust note as well.
Why guess. Flow test the headers. From there you can use the available flow formula's to determine the maximum hp capable of being produced by using this part. Then make sure there is a match with the turbo's flow. Too much flow can be worse than too little flow when pairing header exhaust to turbo's.
Posted some photos 8 days ago. If only people would use the search tool...
https://www.6speedonline.com/forums/...positives.html
