Bumper Support Removal
Old Dec 24, 2008 | 01:22 AM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
How much time for front and rear please from the experienced lightweights among us & also any pics would be welcome ?
Old Dec 24, 2008 | 08:18 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
I would never suggest removing either bumper support permanently. I speak from experience. If my rear bumper support was not in place during my rear end collision, I would have needed an engine replacement for sure. Not to mention the safety factor for the occupants. My 2 cents.
Old Dec 24, 2008 | 11:00 AM
RCH's Avatar
RCH
I am planning to leave the front one in place from a safety perspective and just take the rear off, I guess If I need a new engine my insurance as the car is seriously damaged my insurance will pay for that. And should I experience a rear impact the engine etc should protect somewhat
Old Dec 24, 2008 | 11:08 AM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
To remove the rear crash bar and it's collapsable shock tubes would probably be less than an hour. You will then have no place to attach the 2 bumperettes and will have 2 holes in your bumper that need to be addressed. In addition to what BlackHorseTurbo said about vulnerability, you will lose the tow hook attachment hole. Total weight saving including heat shield is 19 lbs.
The front would probably take a similar amount of time but again you will lose the tow hook attachment hole. The front assembly weighs slightly less but I didn't remove mine and thus don't have an exact weight.
If you take either of them off, the bolts thread into a permanently-attached nut on the bottom of the aluminum piece. Don't try to twist the nut off the bolt.
Old Dec 24, 2008 | 11:47 AM
RCH's Avatar
RCH
Al tvm for that, in Europe we don't have bumperettes thankfully & I only plan to remove the rear
Old Dec 24, 2008 | 12:36 PM
Al Norton's Avatar
Sorry---had I known you were ourside the US I wouldn't have gone on about the bumperettes.
Old Dec 26, 2008 | 01:51 AM
RCH's Avatar
RCH
I would also guess that aircooled models didn't even have this rear bumper support and brackets, I intend to take off both the alu cross member and and the supporting brackets which I guess are steel and the heavy bit
Old Jan 2, 2009 | 09:04 AM
RCH's Avatar
RCH
Ok finally got round to taking my rear bumper off, took circa 20 minutes once I figured how, needed a the jack to get to the philips screws at the top bumper corner in the wheel arch.
"Remove rear bumper cover: 4 phillips on top, 2 phillips on bottom, 4* 25 torx on bottom, 2* 20 torx in the wheel well + 2 phillips in the wheel well near top each top corner . Unplug the wires.(easy) " Bumper is very light in weight and can be easily handled by one person.
This is what Marksi car looks like with it removed, I haven,t got there yet but will tomorrow, I will leave the two impact rear units on just as he has though.
My front bumper support will remain on the car too.
Old Jan 2, 2009 | 10:17 AM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
Probably going to remove these on our car and make something a bit more lightweight to take their place. Best of both worlds IMO for a car that will see street use from time to time.
Old Jan 2, 2009 | 11:01 AM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
Richard you may as well remove the bumper support mounts. They both probably weigh 7 pounds and are pointless at this point.
Good luck!!
Old Jan 2, 2009 | 01:09 PM
Steve Theodore's Avatar
Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !
What did you have in mind Wes? Something made out of a lighter material or something else entirely? Thanks!
Old Jan 2, 2009 | 01:50 PM
MotorsportsR's Avatar
MotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to behold
A few pounds is not worth injury or your life! Please reserved these kind of talk for teens that got more ***** then brain (peace!!!). I would removed the carpeting in the car before I removed the bumpers! 19 lbs? Make sure washer fluid is empty and add 3 gallons less fuel every time you go to the pump. Problem solved!
Old Jan 2, 2009 | 01:56 PM
LamboTT's Avatar
LamboTT has a spectacular aura aboutLamboTT has a spectacular aura about
Can you remove the rear bumperetts and leave the bumper support? Obviously there would be 2 holes there for the engine to breath better,lol.
Old Jan 2, 2009 | 03:17 PM
Understood, but some of us look at this from a weight distribution perspective. Removing weight from the rearmost part of the car is important when you want to improve weight distribution, so there are some good ideas floating around here. Removing weight from the front of the car is not as acceptable towards that goal. I definitely hear you about safety though, and agree that everyone should keep that in mind.
Old Jan 2, 2009 | 03:18 PM
I don't believe so, since I'm 99% sure that the bumperettes are connected to the rear bumper.
