Problem with Ruf Exhaust
Old Sep 14, 2004 | 11:35 PM
P Funk's Avatar
P Funk is infamous around these parts
Hello:
For the second time now I have had this problem with the Ruf exhaust on my 03 TT X50.
The first time, a check engine light came on warning me about a faulty O2 sensor. I took the car in and had it checked out; there were no problems with the O2 sensors. So Ruf replaced the exhaust and the car was fine, no faults.
Ok so now its 2000-3000 miles later and the check engine light just came on again. My guess its the same fault code. So now I have to take the car in for another round of diagnostics.
Anybody else have this problem? And what to do? I figure the 100 cell cats have something to do with it. My options are, go with two hundred cell cats, get my money back, or try to fix the problem some other way.
Much appreciated.
Old Sep 14, 2004 | 11:47 PM
Bruce's Avatar
Member
Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !
CEL
Make sure it's the same fault code before making any decision. Check engine lights come on for numerous reasons. I haven't had the check engine light come on since doing my Ruf conversion and numerous people on this board have the Ruf exhaust without problems so hopefully your present problem is not exhaust related.
Old Sep 15, 2004 | 12:12 AM
P Funk's Avatar
Hi Bruce:
I agree with you and hope its something else. I have an appointment next week to bring it in, so between then and now I was hoping to get some feedback from the various gurus around here.
Thanks.
Old Sep 15, 2004 | 12:57 AM
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
yah, so many people have 100 cell cats without CEL's. I had one 6 months after my fabspeed was put on, but it was the Mass Air thingy. The dealer just replaced it.
Old Sep 15, 2004 | 06:19 AM
Kurt RSF's Avatar
From: Rancho Santa Fe, Jackson Hole, Clearwater Beach
Kurt RSF is infamous around these parts
I've had that happen to my car twice since installing the Ruf exhaust.
The first time I took it into the dealer, the technician told me what the fault code was, and he reset it.
The second time I tried something I read about on this forum, and the car reset itself.
Maybe someone can find the post? It had something to do with disconnecting the battery for 10 minutes, then putting the key in the ignition but not starting it right away, or something?
Sorry I can't remember.
Old Sep 15, 2004 | 06:23 AM
Kurt RSF's Avatar
I found the post. This is from Todd @ Evo. I did this and it turned off my check engine light.
"I am sure that it is something simple. Typically when the CEL comes on and the car is still running perfect it is a mal-adaptation of the ecu or another simple fix. The MAF could be bad, however if this is the case, there are usually drive-ability problems. I find that cars that do not get driven regularly have more issues than those that get driven daily. Can you have the car scanned to determine what the exact code is? If not, disconnect the battery for 10 minutes and reconnect it. Then synchronize the TB by turning the key to the on position (without starting it) and let it sit for 2-3 minutes with the drivers door open. This will reset the computer and reset the TB calibration. If the light is off after this procedure, then you had a "soft fault code" that should not come back after the car re learns during the adaptation process. If the code does come back, we need to find out what the code that is causing the CEL. Call me with any questions. Take care, Todd"
Old Sep 15, 2004 | 09:11 AM
P Funk's Avatar
Kurt you the man.
Thanks for the help, I am going to go out and try this procedure right now.
Old Sep 15, 2004 | 09:24 AM
xico's Avatar
Exotic Performance
xico is infamous around these parts
Get your money back and buy a Phoenix exhaust from Cargraphics , you will love it.
Old Sep 15, 2004 | 09:50 AM
RufMD's Avatar
RufMD is just really niceRufMD is just really niceRufMD is just really niceRufMD is just really nice
I wouldn't change my Ruf exhaust for anything.
In fact, my entire car is a keeper.
There it is, end of story...
Old Sep 15, 2004 | 12:52 PM
P Funk's Avatar
It worked!
Thanks Kurt.
Old Sep 15, 2004 | 02:40 PM
RufMD's Avatar
Re: It worked!
Originally posted by P Funk
Thanks Kurt.
NO NO NO ! You have to sell the exhaust !
Old Sep 16, 2004 | 12:07 AM
P Funk's Avatar
Marcos AMV8
Dec 18, 2015 06:03 AM
Money2536
Sep 1, 2015 04:56 AM
gulf gt
Aug 27, 2015 10:27 AM
Ferrari
Aug 24, 2015 04:35 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
