Were is the Evap purge cannister???
I installed a 75mm plenum and TB and now have the CE light on saying P0444 Evap canister. I found the plug (2 wire looks like the boost solenoid plug) but cant find were it plugs into! I removed the TB, dropped the engine a bit and I still cant locate it? Can anyone tell me were it is or better yet show a diagram or pic? Thanks!
I'm not sure if you are looking for the same thing but the Charcoal Canister is ..... Remove the front passanger wheel well liner and it will be right under the fender by the door.
Looking at your post I don't see how the two could be related other than you not hooking up all the vacum lines correctly which could trigger the code, or maybe the connector should be attached to the gray selenoid in your picture that has something to do with the vacum lines, I'm not sure about that thou.
Can you clarify what are you reffering to? Was it the cannister?
Btw. I love the look of your car with the wheels, got any more pics?
bIt is a small plastic inline piece with a 2 pin connector on it that is in the hose off the top of the TB Plenum.....
Dealer told me it was 4 hours labor to replace it ($140 an hour). I dropped the motor down a bit and it took me .5 hours
r
