Boost problem?
Old Jan 21, 2009 | 08:25 PM
N1_kT's Avatar
N1_kT is infamous around these parts
Boost problem?
i just bought a 01 996tt and its bone stock . The Stock boost gauge is reading 0.5 bar. I want to know if this is normal. Thanks for your help in advance.
Old Jan 21, 2009 | 08:26 PM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
I am pretty sure stock boost is supposed to hit .7 bar...
Old Jan 21, 2009 | 08:27 PM
disconnect the battery for 10 minutes. Then try again...
it should be peaking at least .7 bar maybe its in limp mode.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 21, 2009 | 09:08 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
make sure the boost pressure sensor is connected properly. Right behind the plenum at the beginning of the y pipe on top of the motor. Happened to me once and wouldn't boost beyond .5 bar.
Old Jan 21, 2009 | 09:30 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Which gear are you looking at the boost? Punch the car in second gear all the way to red line, if boost is lower than 0.7bar then do what Markski said.
Evan5469
Oct 29, 2015 06:39 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
nal991
Sep 11, 2015 09:05 AM
rsdub
Sep 10, 2015 03:30 PM
flewis763
Sep 10, 2015 01:08 PM
