Blew a Tire on a way to work...Tire Pressure Monitoring System?
Old Jan 16, 2010 | 01:19 PM
  #46
timf's Avatar
timf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud of
Tpms
I love having tire temp and pressure displayed - gives me peace of mind that I'm not unwittingly shredding a tire or have a slow leak :-)
As for Nigel at Orange - best to give him a phone call as email is not his forte !
The phone number is on the Orange website.
Old Jan 16, 2010 | 04:38 PM
  #47
Patrnflyr's Avatar
Patrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant future
I found the Orange TPMS model P409S on Amazon for $139.00. I thought it was a pretty good deal since I couldn't take advantage of the group buy. Also, my son found an app for the iPhone/Touch which monitors these sensors so you don't have to install the included monitor. I have the center console plus a Kenwood some I'm sort of crowded for space there.
Are you all happy with the monitors? I noticed one says he loves his. I'm coming from an M6 which had it integrated into the I drive and it was a nuisance. I just would like the added insurance of knowing the tire's pressure.
Also, I noticed a balance vibration on my brand new PS2's on the HRE's P43's that I got last week already balanced. We have the new balancing system at our tire place so I could do both the install and road force balance at the same time. Thanks!
John
Old Jun 11, 2010 | 01:17 AM
  #48
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
John are you saying it is possible to use the iphone as monitor and just buy the sensors and correct valves in order to get the tpms working?
Ciao JE
Old Jun 11, 2010 | 01:27 AM
  #49
Turbo Fanatic's Avatar
Had mine installed at the local America's tire. they had everything needed in stock to make it work with almost any wheel . Got a set on My Champion wheels and a set on my Stock Hollows
They actually strapped the sensors inside the champion wheels and had adapters to make them fit the non standard Champion wheel stems. The set on the champions reads 2 psi low (probably due to the adapters), but the readout is consistent and totally usable. Considering how easy it is to damage these expensive 25 series tires by running low (and it's not easily visible) this is cheap insurance.
Old Jun 11, 2010 | 04:25 AM
  #50
Patrnflyr's Avatar
No, Mr. C4, it doesn't use your I phone. I found out since that post that it's simply a store resource that let's you pick out model numbers and store data. It won't take the place of the monitor. Sorry. John
Old Jun 11, 2010 | 09:14 AM
  #51
Mr. C4's Avatar
OK thanks John!
What is the final verdict on the valves, does the Orange TPMS fit the hollow spoke or not without modifications or do they require a special sensor and valve?
Old Jun 11, 2010 | 09:17 AM
  #52
boss351's Avatar
boss351 is just really niceboss351 is just really niceboss351 is just really niceboss351 is just really nice
Originally Posted by Mr. C4
OK thanks John!
Go back a page. Yes, they have an alternative stem and I have used them now for several track days in OEM hollow spokes.
Old Jan 3, 2012 | 08:16 PM
  #53
jakeblade's Avatar
jakeblade is infamous around these parts
How does one go about getting the new alternate Valve stems for the hollow spoke wheels?
I see the system listed on Amazon but I see no options for different valve stems.
Has anyone ran into problem with these on the Hollows or are they all still performing well ?
Thanks in advance for any feedback.
Old Jan 3, 2012 | 09:11 PM
  #54
code7rpd's Avatar
code7rpd has a spectacular aura aboutcode7rpd has a spectacular aura about
Damon - will any of the Tirerack TPMS systems work on DPE wheels?
Old Jan 4, 2012 | 03:08 PM
  #55
jakeblade's Avatar
Has anyone tried these?
http://www.tpms.ca/PTSD4info.html
Nowhere as nice but alot easier to use and can be swapped between track wheels and street wheels easily (as well as other cars). I am not sure if there is a downside to these but I have to say these look to be alot more flexable and perform the same task.
Orange is sending me a sample valve stem to check out. They did not say that they had any other stems ...only what was in the standard kit. If there was a special stem then maybe they are still in development or the person that responded to me from Orange was not informed.
Jul 29, 2019 11:13 AM
horsepowerfarm
Sep 10, 2015 06:09 PM
The Oss
Aug 24, 2015 08:19 PM
