Blew a Tire on a way to work...Tire Pressure Monitoring System?
Old Feb 5, 2009 | 10:51 AM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
So today I'm driving the 911tt to work today, all is good but since yesterday the car was pulling a little bit to the right. Since it's cold as **** I didn't feel like checking the tire pressures since I just checked it about a wek ago when the car got alligned. Well I'm takin an off ramp and dang, the whole tire shoot out an seperated from the rim!!!
So, I'm on the ramp in my suit in blistering cold changing the tire at an incline....how fun!!!
I was shocked to see that the 2002 911 doesn't have some kind off tire pressure monitoring system. Are you guys using some aftermarket alternative?
Old Feb 5, 2009 | 10:55 AM
DNugget991GT3's Avatar
same thing happened to me twice
the first was within one week of ownership
the last time it happened was on january 1st 2009
the tire came off the rim while i was on the highway going about 60-65mph
it was the rear wheel
and i think it was about 25 degrees that day
Old Feb 5, 2009 | 10:58 AM
vbmw335's Avatar
vbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant future
did you hit a pothole? I gotta to watch out as well. We have no shortage of potholes here
Old Feb 5, 2009 | 11:15 AM
XLR82XS's Avatar
It does not sound like a tire PSI problem if the tire dropped that fast in pressure. If you had a blow out it was caused by faulty tire, puncture, impact, etc... There are aftermarket systems but I (and friends) have not had luck with them.
Old Feb 5, 2009 | 11:32 AM
adam699's Avatar
I think that the pressure dropped and I didn't notice. The car was sitting for a long time and the rims probably dont seal too good. The car is new to me and how it drives. So at one point it crossd my mind that the right side seems louder going over bumps, so I was gonna get off the highway exit to check on it. Once on the ramp taking a turn the tire separated. Messed up my wheel liner a bit too. I'm gonna get one of these aftermarket systems and see how they work, I see that the valvesteem mount ones are quite cheap and wouldn't need the rim to be taken apart for battery changes and such.
Old Feb 5, 2009 | 11:39 AM
adam699's Avatar
I dont know if it was a blowout, surely looked like it Basically I was left with the tire in 3 pieces. The 2 sidewalls and the midle.
Old Feb 5, 2009 | 12:05 PM
Alpha's Avatar
Alpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud of
Adam -- I would be cautious about using the valve stem/cap mounted tire pressure indicators. I've read that over time, they can become defective and actually cause air leaks through them.
Glad to hear that you were able to maintain control of your car after the blowout, without injury.
Old Feb 5, 2009 | 12:12 PM
damon@tirerack's Avatar
Moderator
......There are aftermarket systems but I (and friends) have not had luck with them.
TPMS wansn't around much before about 04, and didn't become mandatory until 08.
We have two systems, the Hella and the Orange Electric. I use the Hella system in my F-150 and it works excellent.
Hella:
http://www.tirerack.com/a.jsp?a=BH1&...ailA.jsp&ID=51
Orange Electric:
http://www.tirerack.com/a.jsp?a=BH1&...ailA.jsp&ID=55
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Feb 5, 2009 | 12:40 PM
timf's Avatar
timf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud of
I had the same problem - wrecked a good tire and decided to fit a TPMS.
But I found to my cost that the Hella system won't fit thru' the holes in the rims. Still don't have a TPMS :-(
Maybe the Orange brand are slightly narrower and will fit ?
Old Feb 5, 2009 | 12:46 PM
TonyNJ's Avatar
TonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of light
I just got the Orange Electric system from Tirerack and had Paul from Protosport do a custom install on my console and this system is incredible. It gives you tire pressure display on all four sides on the monitor as well as temperature. I'll post some pictures of the install tonight.
Old Feb 5, 2009 | 03:47 PM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
Will these work with BBS made Porsche hollow spoke turbo twists...?
TIA
jeff
Old Feb 5, 2009 | 03:53 PM
adam699's Avatar
Good info, I'm definatelly getting a TPMS. This boo boo cost me $500 bucks today that could've been easily spent on mods or strippers....
Any confirmation if the said systems work with what wheels? I got stockers now, but when "Change" finally comes I might get some rims Would be neat if we can get a list.
Old Feb 5, 2009 | 06:00 PM
TonyNJ's Avatar
I believe they do, I know that the Hella system does not work with most Porsche wheels.
Old Feb 6, 2009 | 04:21 AM
tscales's Avatar
tscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to behold
I assume you mean wasn't around on a Porsche. My 2001 Corvette had TPMS. Heck my Prius has it
Old Feb 6, 2009 | 05:33 AM
Tony, could you post pictures of your display install. I warn you, I might copy you.
Thanks.
Jeff
