Heavy Clutch Pedal on my Turbo
Old Feb 8, 2009 | 08:14 PM
flat6's Avatar
flat6 is infamous around these parts
Just a quick question to all you tech heads. Lately my Turbo clutch seems to be quite a bit heavier than normal. My question is this. Do clutch accumulator's go bad on these cars?
Old Feb 8, 2009 | 08:19 PM
OCTurbo's Avatar
OCTurbo is infamous around these parts
very common problem. Mine just went bad. I had the accumulator and slave replaced.
wross996TT's Avatar
although not a tech head, I can tell you both accumulators and slaves go bad. do you know how to test your accumulator?
Checking accumulator
1. Cold start engine (accumulator temperature approx. 20°C) and let run for approx. 20 seconds (accumulator is full).
2. With the engine switched off, depress the clutch pedal repeatedly until an abrupt rise in pedal resistance against your foot can be felt (accumulator is empty). While doing this, count the number of depressions
carried out up to the point of the rise in pedal pressure.
3. If the number of times the pedal was depressed is over 35, the accumulator is faulty and must be replaced.
(thanks loren)
Old Feb 8, 2009 | 09:03 PM
JonnyTTSB's Avatar
JonnyTTSB is infamous around these parts
Mine went bad and I replaced. So much better.. Clutch feels like new...
Old Feb 8, 2009 | 09:13 PM
DNugget991GT3's Avatar
yup had this problem with my 996
VERY common
and it always goes bad at the worst time
for example
on a friday during rush hour traffic from a major tunnel in nyc right in front of a toll booth
Old Feb 9, 2009 | 03:42 PM
JonnyTTSB's Avatar
LOL.. Mine blew in line to start an autocross run! I was so pissed!
Old Feb 9, 2009 | 04:57 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
A very good reason to go with the GT2 style setup and get rid of the the accumulator.
Old Feb 9, 2009 | 07:55 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
When you do the replacement, the accumulator is in a very inconvenient place, and therefore hard to get tight. If you don't get it tight, Pentosin comes out and can get onto the headers. Since Pentosin is flammable, that is not good. See Mikelly's posts on his encounter with this issue...
Jon
Old Feb 9, 2009 | 09:59 PM
c4s 2nv's Avatar
c4s 2nv is infamous around these parts
does this also go for the c4s?
c4s 2nv's Avatar
my cluch pedal is hard too, but a tech said that it was signs of a worn clutch.
Old Feb 10, 2009 | 05:38 PM
vbmw335's Avatar
vbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant future
My dealer says my clutch accumlator needs replacement. I had not felt any problems with the clutch. Not sure if easycare covers this...any idea on how many hrs of work this is and how much does it cost ?
TIA
Old Feb 10, 2009 | 05:41 PM
ttboost's Avatar
I know of a member here that seemingly had the accumulator go bad and never replaced it, just keeps driving it. I drove it, the pedal is a little harder, but it's not bad! You get used to it.
Old Feb 10, 2009 | 08:20 PM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Add me to that list. I was told my accumulator was bad about 5000 miles ago.
I figure I will fix it when I do a clutch upgrade when more power dictates.
Old Feb 10, 2009 | 11:00 PM
Prche951's Avatar
how many miles did you guys have on your cars before the accumulator problem surfaced?
Old Feb 11, 2009 | 04:11 AM
ttboost's Avatar
Mine went about 48K. Warranty, so I fixed it along with the slave...
