Battery Preservation
Old Feb 14, 2009 | 08:40 PM
gwapo996tt's Avatar
gwapo996tt is infamous around these parts
Are there any Cons in removing the battery negative cable when the car is not in use for serveral days in the garage? Of course the hood would be partially open so I can re-connect the battery and the driver's side window will also be partially open so I can close the door.
Old Feb 14, 2009 | 09:12 PM
s14roller's Avatar
s14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to behold
No i dont see how that wold hurt the car...also consider hardwiring a battery tender
Old Feb 15, 2009 | 06:42 AM
landjet's Avatar
Why bother. Get the Porsche model battery maintainer that plugs into the cigarette lighter. I leave it in most of the winter. No issues.
Old Feb 15, 2009 | 08:23 AM
wross996TT's Avatar
The only problem is that the DME will need to perform a learning and adaptation routine for the throttle adjustment unit.
Old Feb 15, 2009 | 08:41 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
I agree. The Porsche maintainer is cheap and works great!
Old Feb 15, 2009 | 09:36 PM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
Also consider that your clock and radio presets will be reset and you will need to re-enter the radio/NAV code for it to work. Battery tenders start at $50.
Old Feb 16, 2009 | 08:18 AM
PeterK's Avatar
PeterK is infamous around these parts
I hardwired a $19.99 Walmart unit into the battery terminals. My 2004 battery is still in the top shape!
Old Feb 18, 2009 | 05:42 PM
SlimJim's Avatar
SlimJim is infamous around these parts
+1 Just ordered mine from ebay...didnt start my car for 2-3 weeks and my battery couldnt start the car...
Old Feb 19, 2009 | 01:29 AM
TunaRollZ's Avatar
TunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of light
i keep my negative disconnected after i drive the car. I drive the turbo once every few months which always discharges my poor lightweight odyssey battery. been through many batteries to-date thanks to deep discharging.
As others above have mentioned; ECM needs to relearn, throttle position adjustment, radio settings, etc. No biggie for me since I don't use the radio when I drive the p-car.
PS - if you end up doing this, don't lose that radio code!
Old Feb 19, 2009 | 05:56 AM
XLR82XS's Avatar
Battery maintaner. Cheap, easy to hook-up & use.
Old Feb 22, 2009 | 07:37 AM
2003tt's Avatar
2003tt is infamous around these parts
I do the same thing, but usually not for the entire winter as I also plug it into other cars too. It is s low but effective charger.
Old Feb 22, 2009 | 08:11 AM
chucky0431's Avatar
chucky0431 is infamous around these parts
Hey guys, a little bit of topic, but still battery related. I just received my 996, shipped from Miami to Curacao, they disconnected the battery from it. Had it shipped in a 20' container. They closed the hood, so i had to do that little thingy on the fuse box, connect a battery booster on it so I can pop the hood.
TunaRollZ you mentioned a code. What code is that? After I connected the battery back, the car started perfectly and now issues with the radio. Should I be concerned? Never had this code.
Thank you,
Ricardo
Old Feb 22, 2009 | 08:57 AM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
2003+ no need for the code, the radio is paired with the DME
Old Feb 22, 2009 | 11:50 AM
chucky0431's Avatar
Thx Danyol
Old Feb 22, 2009 | 03:13 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
I've been using this one when I don't drive my car for a week, easy to use...
http://e-partssales.com/Merchant2/me...de=996ttengele
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
