DME code 0160
Old Feb 20, 2009 | 07:20 AM
andymac's Avatar
andymac is infamous around these parts
DME code 0160
Haven't checked the codes in my car for a while but checked it with my Durametric today and found this :
P0160
Porsche fault code 20 - O2 sensor behind CAT.conv.
Bank 2
Car has been running fine and still does but has had a little occasional misfire on idle when warm??????
Could this of been the cause?????
Whats best course of action ? Replace sensor ?
Any tests?
Old Feb 20, 2009 | 08:48 AM
andymac's Avatar
Just to add
The occasional misfire was on cylinder 5 which I believe is bank 2.
Plug and coil was changed but made no difference
Old Feb 20, 2009 | 09:29 AM
wross996TT's Avatar
Well P0160 is a type 2 error meaning no signal....either it is has a poor connection (loose/corroded), disconnected (signal or ground wire) or its dead. You can test it using a data logger, but without that, I would check connections, if they are OK replace the sensor.
Old Feb 21, 2009 | 06:16 AM
andymac's Avatar
I have the durametric software. What data boxes do I need to tick ?
Also am I right in thinking that bank 2 is on the right hand side if you look at the engine from the rear?
Old Feb 21, 2009 | 08:03 AM
wross996TT's Avatar
Bank 2 passengers side
Old Feb 21, 2009 | 08:06 AM
andymac's Avatar
Cheers mate
Old Feb 21, 2009 | 01:01 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
Wross, you are just a wealth of information..
Old Feb 23, 2009 | 10:07 AM
andymac's Avatar
Done some datalogging and found this. Appears the 02 sensor on bank 2 has no resistance? Does this confirm its faulty?
O2 sensor resistance behind cat bank 1 = 0.99 to 1.00
O2 sensor voltage behind cat bank 1 = 0.88 to 0.89
O2 sensor resistance behind cat bank 2 = 0 to 0
O2 sensor voltage behind cat bank 2 = 0.69 to 0.74
Just want to be sure before I buy a new O2 sensor
Old Feb 23, 2009 | 03:21 PM
wross996TT's Avatar
well...could still be loose/bad wire...if you have checked all the wiring...then the sensor could just be bad
Old Feb 24, 2009 | 01:32 AM
stevo996tt's Avatar
stevo996tt is infamous around these parts
where can i get one of the Durametric units?
Old Feb 24, 2009 | 01:52 AM
andymac's Avatar
www.durametric.com
have a look on ebay as well
Old Feb 24, 2009 | 02:46 AM
andymac's Avatar
Just had a good look round at the wiring and it all looks solid. Its a 2001 model and the sensor looks a bit tired , covered in rust.
Think I'm going to replace it
intouch1
Sep 20, 2015 06:14 AM
Yogi911
Sep 9, 2015 08:20 PM
