Pentosin fluid leaking need help!!
Old Feb 25, 2009 | 07:20 AM
  #46
Prche951's Avatar
Suncoast no longer has them so you cannot get them there. you will have to pay 450 or whatever now.
Talking to a few other people, there is another option as well and I think JohnD did it this way. On the opposite side of the trans case is a sealed hole, which is the location where the factory GT2 slave attaches. If you machine out this hole to GT2 slave spec, you can install the entire GT2 setup from factory. Parts will be cheaper, but labor will definitely be higher. Not sure exactly what it takes to machine out the hole.
Old Mar 3, 2009 | 11:19 PM
  #47
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
Hey Art, did you ever get this problem sorted?
Old Mar 4, 2009 | 09:20 AM
  #48
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
It is finally fixed, thanks for asking. It was the reservoir, I know they go bad after some time. Did you figure out the story on your tail? Hope all is ok.
Old Mar 24, 2009 | 10:20 PM
  #49
ait109's Avatar
ait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant future
I've been living with the PS whine for a few months now and the power steering went stiff along with the clutch this weekend. I just got a quote from suncoast for the oem parts: Reservoir: $518.20, Accum+o-ring $110, Slave cylinder: $304.
Ed
mxracer
Dec 28, 2015 08:17 AM
WheelsupZR1
Oct 20, 2015 08:36 PM
freddiemac
Oct 7, 2015 11:05 AM
no1joey
Oct 4, 2015 11:23 AM
RajuPatel
New Member Introductions
Oct 2, 2015 03:28 PM
