Pentosin fluid leaking need help!!
Old Feb 21, 2009 | 09:13 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
I noticed that my pentosin fluid is leaking. I know there are three connections on top and touched the furthest one in the back and felt the fluid leaking. Probably time for new reservoir or??? Any help would be appreciated.
Old Feb 21, 2009 | 09:16 PM
GT3 Chuck's Avatar
Administrator
be very careful...pentosin is flammable and has burnt many a Porsche to the ground...it is also very corrosive and will kill your paint/metal parts
Old Feb 21, 2009 | 09:23 PM
raineycd's Avatar
What is Pentosin? Noob question.... I googled it and it seems like a brand of lubricants, brake fluid, and coolants...
art4iza's Avatar
Well the car is alwasy garaged. Not close to anything flammable. But my drive way looks like $hit now
Old Feb 21, 2009 | 09:25 PM
art4iza's Avatar
Used for power steering as well as clutch. Important fluid to check on sometimes. Located at Right side with black cap, written pentosin on it. Hope this helps.
Old Feb 21, 2009 | 10:06 PM
jpflip's Avatar
Take a look to see if it is not the clutch reservoir which us overfilled...
Old Feb 21, 2009 | 11:06 PM
SamboTT@ByDesign's Avatar
Hey Art,
Sorry to hear it. I am assuming it's in the rear. There are a few hoses that can go bad...but the tricky part is that they can mely the inside of the res. So make sure you check it all or you will chase the res. issue. Have you sown it to Betim? Since he has r&r'd so many motors he sould be able to bang it out.
Good luck...How is she runnin?
Old Feb 22, 2009 | 01:29 AM
art4iza's Avatar
Other than the leak she runs pretty hard.
Old Feb 22, 2009 | 04:10 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
Exclamation
be very careful because your car is getting very hot and can start a fire !
https://www.6speedonline.com/forums/...burned-up.html
https://www.6speedonline.com/forums/...-last-oct.html
Old Feb 22, 2009 | 05:04 AM
Mikelly's Avatar
http://www.youtube.com/watch?v=jLTfG5oMWVI
You have several areas where it can be leaking from. You have three lines that connect to the slave cyclinder, plus the accumulator, plus the line that connects the flex line to the green hardline all at the rear.
All the parts to "fix" the leak will run you about $375. Labor should be somewhere around 3 hours or less.
Don't drive that car until you fix it, as the fluid can leak onto the turbos or the cats and the Pentosin fluid has a VERY HIGH flashpoint for ignition. In other words, it takes a LOT of heat to ignite it, but when it does, you will lose your car...
Mike
Old Feb 22, 2009 | 06:25 AM
Prche951's Avatar
Pentosin is also the steering fluid and here is a good warning thread about this fluid. Mike is right, this stuff is no joke.
Old Feb 22, 2009 | 07:07 AM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
+1 to Mike and Prche951.....
Don't drive it. Period.
Good luck and let us know. I dumped 1/2 of the system for the evoms clutch mod and love it....wish Porsche never used the stuff to be honest.
jb
Old Feb 22, 2009 | 11:34 AM
art4iza's Avatar
Thanks guys I will take the recommendation and sit the car down until it is fixed. Appreciate all the wisdom and time. Art
Old Feb 22, 2009 | 11:46 AM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
jb
I did the same conversion, and love it.
Mike
Great info!
Old Feb 22, 2009 | 12:37 PM
jpflip's Avatar
If anybody ever start a group buy for the EVO clutch mod I'm in....
