Has anyone had problems with PSM/ABS lights with Hitachi MAF?
Old Mar 6, 2009 | 12:37 AM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
I've been getting a CEL with code p1109 lately...
And recently i've been getting abs/psm lights randomly while driving. Anyone with a Hitachi setup have this problem before?
Can boost leaks cause abs/psm?
I've checked my brake lights, and they work fine.
Thanks in advance
Old Mar 6, 2009 | 06:29 AM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
Hey Thomas,
I have not had one single code issue with the Hitachi MAF, I can most likely say that for Mike and Howie in Alberta, no issues at all! That does not help you of course but at least you know from us guy's in the great white north.
Let us know when you find out.
Ben
Old Mar 6, 2009 | 08:04 AM
torresmd's Avatar
torresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond repute
I have never had any CEL's or lights with the Hitachi. Good luck and keep us posted.
Old Mar 6, 2009 | 08:06 AM
Thanks for posting guys. Looks like i will need to call evoms today.
I'll keep you guys updated.
Old Mar 6, 2009 | 09:53 AM
BigBadBen's Avatar
That might be a really bad move Thomas as you might end up sending your car there for some of these new EVOMS GT30's. The numbers are pretty darn good on pump. Ask Todd
Old Mar 6, 2009 | 11:08 AM
GTstreet996's Avatar
GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !
I have the same exact problem with the Hitachi setup...my right speed sensor. When I turn the streering wheel to the left the asb/psm light illuminate.Fixing the issue today..Good luck!!
Old Mar 6, 2009 | 11:13 AM
I don't mind posting my numbers for you Ben. I made 645 awhp on 94 with my milltek exhaust.
To be honest, i would love to see what your car makes with the gt30's, and when it hits peak torque.
Old Mar 6, 2009 | 11:25 AM
BigBadBen's Avatar
Thomas, I am not making that much more on 94. 666 and 660 HP/TQ. It really is about the curve that is usable on the street. Dyno and street are totally different. Todd could have given me peaky numbers that would have been much more but that was not the point here.
Old Mar 6, 2009 | 02:23 PM
Ben, when i get things sorted, i'll send you a pm with my dyno chart so you can compare. For your eyes only
Old Mar 6, 2009 | 02:27 PM
BigBadBen's Avatar
Gotcha
Old Mar 6, 2009 | 08:25 PM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
No problems with mine...
Old Mar 6, 2009 | 09:02 PM
MBailey's Avatar
Old Mar 6, 2009 | 10:49 PM
Found a boost leak..... It's going to be quite hard to fix.
It's on my turbo inlet duct...
Old Mar 6, 2009 | 10:55 PM
John@SpeedTech's Avatar
Do you have the EVO hard pipe kit? I can't imagine that ever failing.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Mar 8, 2009 | 11:48 AM
19000rpm's Avatar
19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute
P1109
Heavily soiled throttle
Throttle damaged
Mass air flow sensor
Probably your MAF. I don’t know why but some how it can set off the psm/abs when it goes. If it wasn’t for that code I would say brake light switch, which can stick and cause issues independently of the brake lights. You could try putting in a new switch, its cheap and an easy diy, so even if it doesn’t fix it oh well.
tropicatango
Jun 8, 2025 01:00 PM
007AMV8
Oct 19, 2015 09:55 PM
LiquidElephant
Aug 27, 2015 06:17 PM
GSR Autosport
Aug 26, 2015 05:20 PM
