Any problems running stock axles/tranny with 800+rwhp
Old Mar 18, 2009 | 08:57 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Has there been any documented cases of broken tranny or axles on 996tt's pushing 800+rwhp on stock axles/tranny. From roll ons or off the line take offs. Please share your suggestions here. thanks art
Old Mar 18, 2009 | 09:06 PM
Evo650's Avatar
Evo650 has a reputation beyond reputeEvo650 has a reputation beyond reputeEvo650 has a reputation beyond reputeEvo650 has a reputation beyond reputeEvo650 has a reputation beyond reputeEvo650 has a reputation beyond reputeEvo650 has a reputation beyond reputeEvo650 has a reputation beyond reputeEvo650 has a reputation beyond reputeEvo650 has a reputation beyond reputeEvo650 has a reputation beyond repute
Yes. I've broken three half shafts. EVOMS has several upgrades that you should consider.
Old Mar 18, 2009 | 09:53 PM
rbb1991's Avatar
rbb1991 is infamous around these parts
Stock trannys and shaft cannot handle THAT much power. I believe in the 550-600+ range, you will need to upgrade those components.
Old Mar 18, 2009 | 10:30 PM
art4iza's Avatar
Thanks guys for the info.
Old Mar 18, 2009 | 11:12 PM
sharkster's Avatar
Yes if you're drag racing and launching... Just use these (let me know if you want a set):
http://www.sharkwerks.com/products.php?pid=182
Old Mar 18, 2009 | 11:18 PM
WOODTSTER's Avatar
Like Sharkey says,
It depends what you do with the car (how it is driven).
It alot of situations, they might be OK
Old Mar 18, 2009 | 11:51 PM
art4iza's Avatar
How about just roll ons from 2nd or 3rd gears. Would the axles break under these conditions?
Old Mar 19, 2009 | 12:01 AM
Renegades's Avatar
Renegades is a glorious beacon of lightRenegades is a glorious beacon of lightRenegades is a glorious beacon of lightRenegades is a glorious beacon of lightRenegades is a glorious beacon of light
Once you're rolling I highly doubt at those speeds you'd break the axles... It's usually the off-the-line stuff or aggressive 1st to 2nd gear shifts that do the breaking..
Old Mar 19, 2009 | 12:19 AM
sharkster's Avatar
Should be less stressful for sure. Launches eat them up pretty good though.
Old Mar 19, 2009 | 12:33 AM
No they should hold....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 19, 2009 | 01:29 AM
Divexxtreme's Avatar
I wouldn't risk it. Get the Axles from Sharkey. I ran the same ones on my car and never had a problem.
Old Mar 19, 2009 | 07:04 AM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
can the tiptronic trans handle over 700 hp? what do you think the limit on HP should be on a tip?
Old Mar 19, 2009 | 08:12 AM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
I agree with Scott dont risk it however I must confess that I have a stock tranny and axles.
Old Mar 19, 2009 | 08:25 AM
art4iza's Avatar
Thanks again for sharing all the experiences. In your opinion, is 996tt stock axle better than 993tt stock axle? Meaning would it sustain a lot more pressure than 993tt model.
Old Mar 19, 2009 | 08:28 AM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
You should be fine rolling, if your going to launch the car you'll probably want to upgrade your differential with a Guard unit and check out your syncros and ring and pinnion while you're in there, and get a nice set of axles as well. We just got done with these upgrades this week, figured it'd be better to take the proactive approach. Driveshaft Shop makes a great set of axles for the 996tt, they do require a bit of clearance to fit, but compared to stock they're much larger and made of better materials than the OEM units.
