Time to add some power......Beta Test New EPL Turbo Solution
Old Apr 2, 2009 | 03:17 PM
  #76
ttboost's Avatar
Originally Posted by ReeknHavic
Yeah I think Chris is at 701 or something like that. He's running a E85 setup on his 18g.
Wasn't sure, but I thought so. I thought someone here was trying to substantiate the fact that GT28's outflow 18G's. I dont think it matters what type of fuel used? Power is power? If you can flow the air...efficiently... Seems aweful close?
Old Apr 2, 2009 | 03:18 PM
  #77
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Didn't Highhats have a built bottom end? What boost and was this rwd?
This was stock bottom end and rwd. The other plots TTboost and I posted were on a mustang dyno, 28rs and awd.
Bottom line, 28rs's that aren't held back by a k16 hot side (which highhats were), will make alot of power.
Old Apr 2, 2009 | 03:22 PM
  #78
TiALSport's Avatar
TiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond repute
fuel makes a GREAT difference when making power
pump fuel will see anywhere from 9.5 to 10 hp per lb/air where as the real nasty stuff like VP import and E85 can see as much as 12hp per lb/air or more
say a system is flowing 66lb/min with pump fuel, figure you are getting 10hp per lb of air so a 66lb/min car is pumping out 660hp
now take that same car, on VP import: 66lb/min * 12 = 792hp!!
Old Apr 2, 2009 | 03:26 PM
  #79
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
Interesting facts posting up here guys! I'm in the process of adding a pair of GT28rs's to my S4.
Old Apr 2, 2009 | 03:29 PM
  #80
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
Yeah, you're talking about a compressor map. I agree....
Old Apr 2, 2009 | 03:33 PM
  #81
TiALSport's Avatar
published compressor maps you really have to research, some get cut off early say at 126,000 RPM as opposed to 144,000 RPM, so what is actually on the map may not be the full potential of the turbo
Old Apr 2, 2009 | 03:35 PM
  #82
Dr_jitsu's Avatar
Gt 28's making as much power as my GT 30's....that must be a special dyno. What are the 60-130's? I am sold that the 28's are as good as the 24/18's, but 685?
Old Apr 2, 2009 | 03:37 PM
  #83
TiALSport's Avatar
what kind of boost levels are you running on your 30's?
Old Apr 2, 2009 | 03:41 PM
  #84
Dr_jitsu's Avatar
I made 670 but it was a mix of pump and Sunoco 114...I went up to 1.4, spiked at 1.5 for a half second. I am going to get a good boost guage pretty soon.
On C 16 I could probably make more. Also, there were no fans on the car. Dyno was pretty stingy. There is another dyno in town where I could make 700 easy, but I only care about 60-130's.
I also have dual pumps, rails and 60lb injectors.
Last edited by Dr_jitsu; Apr 2, 2009 at 03:42 PM. Reason: not C 16, mix of pump and Sunoco 114
Old Apr 2, 2009 | 03:45 PM
  #85
TiALSport's Avatar
if you went up to 2.0 or 2.1 bar on full C16 your hair would really get blown back
granted, the engine would have to be able to take it
do you have the 3071's or 3076's?
Old Apr 2, 2009 | 03:51 PM
  #86
Tony@epl's Avatar
60lb injectors are pretty small for that kinda power. Have you through about stepping up for safety?
Old Apr 2, 2009 | 03:56 PM
  #87
Dr_jitsu's Avatar
That is not a bad idea, Tony....which should I run?
Tial: I have GT 3076 A/R 63
Old Apr 2, 2009 | 03:59 PM
  #88
Tony@epl's Avatar
All our cars have been running a 72lb or 95lb Bosch injector.
Its one of the best injectors I have ever tested.
Wes from Titan can get you a set. They arent cheap, but they're worth it. Thats what we're running in Audikp's 3071 car.
Old Apr 2, 2009 | 04:28 PM
  #89
ttboost's Avatar
Well sort of...people were seemingly trying to compare 18G's and GT28's with no talk of boost levels, fuels, supporting mods, etc... ALL that does make a difference. I would like to see both turbos at the same boost on the same fuel for a real comparison...
Old Apr 2, 2009 | 05:42 PM
  #90
unvmy996's Avatar
There is no need for larger injectors at his power level . you keep on preaching this over and over again ... just beacuse you cant do it does not mean others cant ...
hows 914.4 rwhp and 809 wheel torque on 60 lb injectors ?? Oh and the purple line was on 100 octane !!!!it made 834 rwhp at only 1.34 bar.. so um ya...
