Time to add some power......Beta Test New EPL Turbo Solution
Old Apr 2, 2009 | 05:46 PM
  #91
ttboost's Avatar
Originally Posted by unvmym3
There is no need for larger injectors at his power level . you keep on preaching this over and over again ... just beacuse you cant do it does not mean others cant ...
hows 914.4 rwhp and 809 wheel torque on 60 lb injectors ?? Oh and the purple line was on 100 octane !!!!it made 834 rwhp at only 1.34 bar.. so um ya...
What turbos and supporting mods?
Old Apr 2, 2009 | 05:49 PM
  #92
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
I want some of that Protomotive Kool Aid! LOL!
Injectors at well over a 100% Duty Cycle and high amounts of fuel pressure are never safe.. But what do you know honestly.. You (And about 95% of Todd's customers) probably don't even really know how a fuel system and regulators work...
I'll stick to the advice Tony, Justin N, etc. have all given me by saying that it's the safest bet to upgrade injectors.
Further more ask EVOMS what injectors they are using Joe's, BigBadBen,etc. cars. Apparently they are LEAPS and BOUNDS ahead of Proto and everyone.. I didn't see any 23x mph Proto cars out there... Hell I didn't see any EPL cars either, but apparently they are doing something right and apparently 60lb injectors WERE NOT CUTTING IT!
Old Apr 2, 2009 | 06:10 PM
  #93
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Wow...
To be honest. I dont know what to say.
Its not magic. Its just air and fuel. When you are flowing enough air to support 914.4 wheel hps on these cars, you will be well out of fuel with 60lb injectors.
So honestly...if the car you posted above had 60lb injectiors, its not making 914.4 hps.
Old Apr 2, 2009 | 06:30 PM
  #94
unvmy996's Avatar
Right .... ill let you tell it .. oh and powell you have been drinking tons of the koolaid allready.... your doing great buddy keep drinking.
Old Apr 2, 2009 | 07:04 PM
  #95
Cossey's Avatar
Cossey is a jewel in the roughCossey is a jewel in the roughCossey is a jewel in the roughCossey is a jewel in the rough
Where'd this guy come from, Honda-Tech?
I know the guys making 1000+hp on the Supras w/ 3.4L motors are using well over 1000cc injectors to supply fuel safely. So if he's using only six 60lb injectors, I don't see how that's even possible with those power levels.
Old Apr 2, 2009 | 07:20 PM
  #96
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
There are certain laws of physics that no tuner can brake. It doesn't take Kool-Aid or some magic fairy dust to realize that the graph above was either done on an engine dyno or hub dyno with a nice correction factor, the injectors where rated at 60lbs at a very low fuel pressure and now have the pressure cranked through the roof, or the injectors might have started at 60lbs (and is now modified to flow 1,000cc or more at higher pressure). Regardless an engine is nothing more than an air pump, regarless of how many cylinders, the brand, or whose tuning the engine, certain laws of physics apply. It'd be best to take some time to learn the fundementals, or before you know it people might assume you to be the one drinking the Kool-Aid.
On your average 3.4L Supra at 1,100 you're well out of fuel with 1,000cc unless the fuel pressure is through the roof. Even then you're running at a duty cycle that could exceed 100%. Is it possible to keep going and make power. Would I put my car on the dyno and run it down the track in that configuration, absolutely not.
Old Apr 2, 2009 | 08:35 PM
  #97
Dr_jitsu's Avatar
Chris,
Todd installed my injectors when I had GT 28 hybrids.
Wes, how much for a set of the 72lb injectors?
Old Apr 2, 2009 | 09:01 PM
  #98
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Hub dyno - thats why I would like to see these cars on a mustang
Old Apr 2, 2009 | 09:03 PM
  #99
Powell's Avatar
Old Apr 2, 2009 | 09:07 PM
  #100
smokinxtreme's Avatar
smokinxtreme has a spectacular aura aboutsmokinxtreme has a spectacular aura about
I want power too...........
Old Apr 2, 2009 | 09:21 PM
  #101
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
Originally Posted by Powell
That's from Family Guy!
Old Apr 2, 2009 | 10:00 PM
  #102
audikp's Avatar
audikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to behold
Do you have an injector duty cycle log of the car you posted about when it was making this power?
Old Apr 2, 2009 | 10:09 PM
  #103
Chris Green's Avatar
Chris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond repute
Tial I made 702whp on my 18's there is no 28rs car that would keep up with me bottom line, I talked to you guys at PRI about these turbo's. they look great and would love to sell them, I just need to prove to guys they will not have much lag over my current set up. Why didnt you guys go billet with these?
PS : no way in hell you can make 914whp on 60lbs injectors. Any 1/4 mile times or 60-130 data on that car?
Chris Green
Old Apr 2, 2009 | 10:29 PM
  #104
onelove's Avatar
Originally Posted by Dr_jitsu
Chris,
We keep the 1,000cc in stock, I can get the 750s for the same price however many big HP cars have just gone with the extra injector. They're $120 each including the pigtails for the injectors and drop right in.
Bosch 1000cc High Impedance Injectors
I'd much rather run at a low duty cycle and make big power, than shoot for the stars and have my ECU requesting 100-110% duty cycle.
Old Apr 2, 2009 | 10:32 PM
  #105
Cossey's Avatar
Hence my post saying "well over 1000cc."
My friend with 625whp on his 1.9L sleeved B18C is running 1200cc injectors, so I can only imagine what the 1000whp guys are running. I think my friend Ray w/ his 3.0L 900+whp Supra is running in the 1200-1400cc range.
