ECU Upgrade
ECU Upgrade
Can anyone advise me on the least expensive but good-(reliable) ECU upgrade for my 01-996tt. Just like evryone else... I want to get the best bang for the buck.
Thanks Pete
Thanks Pete
Give Tony @ EPL a call, since you're in South Florida Chris Green @ USP can likely flash your car on the spot and can show true results that day on the dyno. If you want to make a drive up to Orlando we can also do the same.
Give Chris Green a call at USP. He can flash an EPL file for you on the spot, and test to make sure everything is running as optimal as possible!
Thanks,
Tony
Unforgettable Sound and Performance
7716 Wiles Road
Coral Springs, FL 33067
Phone: 954-755-7772
One option is the Sportec Stage 1 Upgrade. Here are the stats on that kit:
Sportec 993 TT Stage 1 Upgrade
ECU reprogramming, MAF Meter, air filter, high performance
catalytic converters, modofied air intake.
Max. Performance: 338 KW (460 PS) @ 6200 RPM
Max. Torque: 630 NM @ 3800 RPM
Max. Speed: approx. 303 km/h
Max. Acceleration: approx. 4.0 Seconds 0-100 km/h
Feelgood MD
Mar 24, 2016 09:35 AM
albert@velosdesignwerks
Sep 3, 2015 11:11 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
