New Project called B9R Under Construction...at BBi
Rating: Thread Rating: 4 votes, 5.00 average.
Old Jun 30, 2009 | 04:54 PM
  #286
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Originally Posted by art4iza
Last question's answer: Stock size.
Stock size valves?After all that pretty porting?Just curious Art what turbos are you using again?GT35's?
Old Jun 30, 2009 | 06:50 PM
  #287
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
We will be using GT35's, VR was nice enough to give me some of his older turbos
Old Jun 30, 2009 | 06:51 PM
  #288
Prche951's Avatar
Just as an aside discussion, what are the largest turbos that anyone has installed on any of these cars.
Old Jun 30, 2009 | 06:59 PM
  #289
cjv's Avatar
cjv
Moderator
GT42R's
Old Jun 30, 2009 | 07:03 PM
  #290
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
Art!! AFRIKENMAZING!!! Nice port work!! hey are going to flow serious numbers!!
Is the Block or heads being receiver grooved for the o-ring gaskets?
Old Jun 30, 2009 | 07:06 PM
  #291
Prche951's Avatar
Originally Posted by cjv
GT42R's
now that is huge....
Old Jun 30, 2009 | 07:25 PM
  #292
cjv's Avatar
cjv
Moderator
You are forgetting we are dealing with a displacement that is about 33% larger than a stock 996tt. Unlike the stock Porsche, every part has been designed to be a match flow wise.
In our origional tests we used GT35's, GT40's and GT42's. Each turbo excelled in a different area depending on what 5000 rpm range you want to operate. The motor will work well between 3200 and 9400 rpm's, however the turbo chosen decides what range the motor is most effective. None of them are most effective in the full range. The final decision will be dictated on the final usage of the car.
Old Jun 30, 2009 | 07:29 PM
  #293
cjv's Avatar
cjv
Moderator
[quote=art4iza;2445759]chad, after reading half way through your thread and i almost creamed in my pants excuse my french. The whole work on one side and the lifts and head flows on the other. Pistons look amazing as well as the rods, wow Intense work and a huge research, congrats to you my friend. I think you know more than the whole porsche motorsports in germany [quote]
Art,
There isn't a single stock porsche part in the motor. Most parts like the oil pump, pistons, rods, crank, bearings, cams, cam housings, lifters, valves, springs, liners, liner housings, studs, head gaskets, oil squirters and keepers were designed and made by different members of our team.
The only stock part is the case and it was aline bored, shuffle pinned, bow tailed and machined for the three index oil pump along with machined for the 105.7 mm liners, 12 mm studs and vacuum main seals. Frankly, we have concerns of this spanish case being able to hold up to the potential power of this motor. The Boxer motor by design is very smooth up to approx. 7000 rpm's. However as the opposed pistons approach 9000 rpm's the forces are exponential and with the power we can produce the pressures can cause the case to explode. We are going ahead with this motor and the case we have. We will be limiting the upper end power in the mean time. We are in the process of having a billet case designed and manufactured to withstand the power potential in the upper rpm ranges.
Old Jun 30, 2009 | 08:03 PM
  #294
Prche951's Avatar
Chad, your car will be a monster. is your economy file going to be a 2 cylinder cutout, so you run on 4 cylinders....
Old Jun 30, 2009 | 08:10 PM
  #295
cjv's Avatar
cjv
Moderator
Haven't figured out the gallons per mile yet.
Old Jun 30, 2009 | 08:12 PM
  #296
art4iza's Avatar
Chad, this will be something I've never seen before. I will keep reading more on that thread, I only went half way through, good work.
Joe, yes the valves are not stock highly modified and springs have been modified too.
Dennis, I know someone that has already used GT40's but have a lot of lag but on top....
I think Chad's experience here is extensive and has hands on with wealth of knowledge. I also hope not to blow my motor either
Old Jun 30, 2009 | 08:14 PM
  #297
Prche951's Avatar
I hope you own a gas station (and you better not say you do)
Old Jun 30, 2009 | 08:16 PM
  #298
art4iza's Avatar
Corey thanks for the kind words but I think if you look at Chad's port it stands out more. His flow #s and lifts are unreal. Second part of your question, yes.
Old Jun 30, 2009 | 08:18 PM
  #299
cjv's Avatar
cjv
Moderator
If you only went halfway ......... skip to the last two pages. We have scraped the earlier rods and pistons and the new ones are in another world. They were CAD designed using the 962C's piston design as a core (a la oil cooling cores) and then we had plastic ceramic mock ups made to check all dimensions and clearances. In addition the rods were stretched to 132+ mm in length.
Old Jun 30, 2009 | 08:19 PM
  #300
Prche951's Avatar
well after all this I need a smoke. Gotta go have a cohiba and a glass of Remy extra fine.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
